Hi We have a envelope at the top right corner of our screen.. How do we get rid of it?
  • 583 Answers
Your satellite or cable service has a message for you on your account. Depending on which service you have (DirecTV, Dish Network, etc.) the procedure will be slightly different. But a generic procedure is outlined below:
Using the remote provided by your television service provider, click on menu (might be system or something similar).
Once you are in the system menu, look for account services, messages or something similar to that (it maybe in a sub menu).
Look for messages, mail, or something similar and then read mail or inbox. Once you have read the message(s), the envelope will clear off of your TV.
Posted on Apr 04, 2011
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
Our envelope is black with a white border on tv screen in rh top corner. How do I get rid of it?
Press menu on your remote, scroll to 4.mail message. Just an update on Dstv's subscription Terms and Conditions. Exit button and envelope gone
Apr 04, 2011 | Televison & Video
How to print the envelopes on samsung laser printer CLP-310
Try printing address on envelope with MS Word as it has the facility under Tools/Envelopess where it will store the 'from address'
Both addresses are fully ajustable ie. left or right, up or down - no doubt there are other programmes for your purpose.
Thanks
I usually print the 'from' address in the top left hand corner on the
DL sized envelopes
Jan 30, 2010 | Office Equipment & Supplies
I have the nokia 5800 xpressmusic which i have just got. in the top right hand corner there is a envelope flashing, when you click on it its says simcard memory full, i have all ready cleared the numbers...
If you've just put your SIM card in your Nokia 5800, you may have noticed a flashing envelope icon at the top of the screen.
This icon indicates that the SIM card's own text message storage is full. This doesn't actually cause problems on the 5800 because it stores its messages in the phone's own memory, but the envelope can look a bit annoying.
To get rid of the flashing envelope:
1. On the standby screen press the white menu button.
2. Select "Messaging"
3. Select "Options"
4. Select "SIM Messages"
5. Delete some or all of the messages from the SIM messages folder using the Options menu.
This should make the flashing envelope go away. You only have to do this once because when the SIM card is emptied it won't fill any more, as the 5800 does not store messages on SIM cards.
Nov 19, 2009 | Nokia Lands Phones
Meassage in top right corner says sim memory full how do i get rid of the flashing meassage
Go to messaging, select options and then sim messages. Delete one or more of the sim messages and the flashing envelope should cease.
Sep 29, 2009 | Nokia 5800 XpressMusic Smartphone
I can`t seem to get rid of the clock or channel on my screen HELP
Press Display or "info" button on Sony TV Remote, on-screen display will disappear. Please use TV Remote, no other remote will work for that.
Jul 15, 2009 | Sony KP-57WS520 57" Rear Projection...
Flashin envelope on screen
well you need to go to your sim msgs, amd delete a few, you will get it in your msg foulder on your phone
Jun 03, 2009 | Nokia 6210 Navigator Cell Phone
Sim memory says it is full when it isn't
go to messaging, click options then go to sim messages,mark all messages then copy to your phone. that's what i did and got rid of the annoying flashing envelope in the top right hand corner of the screen. hope this will work for you.
adrian23
Mar 20, 2009 | Nokia 5800 XpressMusic Smartphone
Cant get rid of message envelope
Could be either a TEXT message, or a Voicemail.. Check both and delete from the system.
Jun 24, 2008 | Motorola Mobility RAZR V3
Help
Hi, solution for your envelope
10 envelopes The print side of the envelopes faces up.
The envelopes are loaded vertically against the right side of the paper support.
The stamp location is in the upper left corner and printed with landscape orientation.
NOTE: For Japanese customers: If you are mailing within Japan, the envelope can be printed with portrait orientation with the stamp in the lower right corner or with landscape orientation with the stamp in the lower left corner. If you are mailing internationally, print landscape orientation with the stamp in the upper left corner.
The paper guide rests against the left edge of the envelopes.
You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned.
Oct 25, 2007 | Dell 810 All-In-One InkJet Printer
Televison & Video Logo
198 people viewed this question
Top Televison & Video Experts
Electro Med Services...
