Question about Briggs Stratton IC Horizontal OHV Engine 305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1
It is a 3.5 hp engine on an edger, that starts but quickly dies and then it won't start unless it sits for quite a while, but quickly dies again.
  • 528 Answers
First thing to check is the fuel filter, if it does not have an external filter then it has a filter at the end of the pickup tube in the fuel tank. Empty the tank and look to see if the filter screen at the end of the pickup tube is clear. If that is not it then you need to remove the carburetor and clean it.
Be gentle and good luck
Posted on Apr 04, 2011
I have a pocket bike that wont start unless u put gas where the spark plug is and then it will run&idle but once u give it throttle it dies there is no high or low screw there 1 screw &the idle screw
Hi, Anonymous more than likely it's clogged carburetor jets, obstruction in the fuel system or a faulty battery for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Common Reasons Why My Pocket Bike Wont Start
Pocket Bike Won Start Help Quick Fix
What To Do If Your Pocket Bike Won Start or any 2 stroke engine
Pocket Bike Not Starting
Jun 01, 2016 | Motorcycles
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
Jeep was overheating, Now leaking transmision fluid and won't start
I don't see how leaking transmission fluid would be connected to the engine overheating, unless the radiator blew up.
You'll need to figure out why it won't start to proceed.
Check for spark and fuel pressure, and of course compression.
Is the check engine light on ?
Jul 09, 2012 | 1988 Jeep Cherokee
When riding in 5th gear starting losing cylinders. and bike dies? then bike won't start electrical start. can' roll bump start bike if i let sit for an hour. thn bike dies quickly. is my m
More likely to be your ignition coils. They heat up and expand this can cause an open circuit which will close up again when it has cooled down. Although, a bad charging system may cause this problem. Check the battery voltage with engine switched off ( approx 12 volts) and with the engine running (approx 14 volts) If you are getting 14 volts then your battery is dead, if you aren't, then your charging system has a fault.
May 06, 2012 | Honda CB 750 Motorcycles
If you let it sit for a few days it will only start by blowing into the tank. will run for a sec. on carb spray. good spark and compression. once you get it running will die at times when heading up a...
I would start by doing a clean and inspect of the carburetor. Look for debris and water in the bowl. Inspect the float to ensure that you do not have fuel in float affecting its operation. Check for freedom of operation of the float and needle. Give it a thorough cleaning of all holes and passages. Be careful to put it together the way it came apart.
I hope this helps get you going again. If you do all that, please let me know how it turns out, and if it does not work we can figure out what else it could be.
Aug 04, 2011 | Garden
Engine starts then quits
does it have a fuel filter, or air? If it does make sure they are both clean and free of debris as priming will force fuel up line but will die as soon as its burned out
May 30, 2010 | Craftsman 25cc Gas Line Trimmer
I have a 1993 tioga motorhome with a ford 460 engine. Last summer in the heat I drove for about 1.5 hours before it just died. I sat for about 20 minutes it started up and ran fine for another hour and a...
I'd be tempted to have fuel pressure checked, if at all possible, when it quits. If nothing else, carry a can of quickstart with you, and when it quits, remove air intake at throttle body inlet, and open throttle plate and give a good squirt of quick start, then try to start it. If it starts for a second or 2, then you know you have spark, but no fuel. I've seen fuel pumps work good while cool, and cut -out when it gets hot. Then sit and let pump cool off for 20 minutes or so, then pump up to pressure again and away we go, until it gets hot again. You might also find if you park in the shade, you'll get further, or even on a full tank. Another good idea would be to change fuel filter in case fuel pump is working too hard pushing fuel through a plugged filter, and causing low fuel pressure.
Mar 30, 2010 | 1993 Ford Econoline
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Briggs Stratton IC Horizontal OHV Engine  305cc 1450 Series 145 Gross Torque 1in x 3 2132in Shaft Model 2053320537B1 Logo
130 people viewed this question
Top Briggs Plumbing Experts
John Trevino
Randy Schumann
Randy Schumann
Are you a Briggs Plumbing Expert? Answer questions, earn points and help others
