Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
PT-53WX56 Hello. I have a Panasonic PT-53WX56 rear projection tv. The other day we turned it on and about 30 minutes later it turned itself off and the red power light blink 3 times. Does it everytime we try to turn it on now. I actually have 2 tvs like this, my mothers is also doing the same exact thing, seems like a way to common problem. I was wondering if you knew what the 3 blinks was for? And if they are even worth fixing. Thanks!
  • Panasonic Master
  • 8,617 Answers
Yes the 3 blink error code means the convergence ics need replacment. very easy you need two stk392-110 ICs and six 2.2 ohm 2watt resistors very easy an inexspensive repair. you can get replacement ICs and resistors at the following link with free instalation instructions with pictures so you can do the repair yourself and save quite a bit as a repair shop usually charges between 4 and 600 dollars for the repair which takes about an hour. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 05, 2008
SOURCE:
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-51hx41e shuts off by itself
older rear projection and should if shut down either display a solid red or a blinking red power light
Mar 24, 2012 | Panasonic Televison & Video
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
SQUIGGLY LINES ON PROJECTION TV FOR ABOUT 10 MINUTES
Change the following capacitors (from repairworld database).
C7154, C7136, C1008, C1011 Front & Side of Convergence Amps
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
