Question about Epson PowerLite 8200i Multimedia Projector
After it being on for 5-10 minutes, just shuts off manually. Already cleaned it out and replaced bulb. Now what?
  • 583 Answers
It sounds like it is overheating. Check to make sure the cooling fan is coming on when you power it up. Please respond with your findings for further help in troubleshooting.
Posted on Apr 04, 2011
My Proxima c170 projector will turn on and run for about 10 minutes, then the entire unit shuts down. It's as if the power was turned off.
Probably is a failed capacitor in the power board. Open the case and look for the can type capacitors with bulged tops and replace them if you can.
Feb 26, 2015 | Televison & Video
Tv comes on then turns itself off
Sounds like the projection bulb is heating up then it shuts off for safety reasons. If you can locate the bulb, there is most likely a screen (wire mesh) that traps dust when the fan is on to cool the bulb. Try cleaning this screen and see if it helps. It could be already too late and you might have to replace the bulb.
Feb 27, 2014 | Sony KP-65WS500 65" Rear Projection...
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
My Sony VPLHS-20 has original bulb, now just shut off 50 mins into the SuperBowl. No fault light, in fact, no lights showing on the display at all. Bulb has around 1800 hours. I waited 10 minute, red...
Pretty sure it the bulb as most are rated at 2000 hours; but also check for full air flow - clean filters etc. Bulbs can run hotter as they age, so air flow is more important, because there is an inside heat sensor that will shut the machine down.
Feb 09, 2011 | Sony VPL-HS20 Multimedia Projector
Toshiba 42HM66 and it shuts off on its own. Im not sure if its getting hot or if the bulb needs to be replaced. It will just shut off at any moment without the 10 sec countdown that happens when I manually...
remove bulb and place in freezer for 5 minutes. the when unit comes on, go into menu and find lamp setting. select and it will ask you if you replaced bulb. select yes which resets the lamp time to zero hours
Nov 10, 2009 | Toshiba 42HM66 42" Projection HDTV
GMP075-3 looks good but shuts off after 10 seconds
Replace the thermostat control sounds like the control contacts are not holding since you cleaned the bulb and the igniter is working the only other issue is the thermal buld being bad, shut it off heat the bulb for three minuts then quickly turn it back on and see if it stays on longer if it does the bulb is the problem.
Oct 07, 2009 | Goodman GMS90703BXA Heater
BenQ 500W projector shuts off after 10 minutes
it has lamp which has 2000hour in normal and 3000 in econom mode to shinenormal then it must be changed and your may already in this state and began such things.
Aug 18, 2009 | Televison & Video
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Epson PowerLite 8200i Multimedia Projector Logo
334 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
