Question about Marc Refrigeration Refrigerators
I have a marc refrigeration MDL-6sc and something is making the timer switch to kick off
Ice buildup in frig above evap coils. Defrost coils seem to work, at least on manual. Samsung mdl RF266AES/XAA
If the defrost element is working the you have to totally defrost the evaporator, kick it back into life & all should be ok. Air intruding into freezer could be the cause of the frost, make shure the seals are ok & in place, make sure the doors are closing all the way.
Nov 20, 2013 | Samsung RF267AERS French Door Refrigerator
Freezer works, fridge does not. The coils in the freezer wear iced over. Unplugged, thawed, turned defrost timer switch til it clicked. Plugged back in. Freezer still getting cold. Assuming defrost timer...
The defrost timer for a model FRS26ZSG is found behind the kick plate at the bottom and front of your refrigerator. You will need to pull the kick plate off. If you turned the timer then that is the defrost timer part number=> 215846602 Defrost Timer I am here should you have questions, Sea Breeze
Jul 30, 2013 | Frigidaire FRS26ZSG
Coil has ice up all the way what can i do as in fixing the problem?some step would be nice?
behind the vented kick panel on the front of the refrigerator is a defrost timer, when the refrigerator is running manually turn the timer until you hear a click which should indicate it has gone into defrost. let it defrost and then make sure the timer is turning, if not replace the timer.
Jun 07, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Any kind of timer switch available for my refregerator which would automatically cut off power for upto 1-6 hours
yes use a 24 hr timer at the wall wher you plug it in .. make sure is able to handle 20 amps or better . like for motor not lighting. home depot should have something for you. mm
Dec 07, 2009 | GE GTS22KBP Top Freezer Refrigerator
Fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 10, 2009 | Refrigerators
Dryer motor has trouble starting
sounds like you are having or go to have a motor problem repl/ motor
Dec 29, 2008 | Dryers
Refrigerators Logo
Top Marc Refrigeration Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Marc Refrigeration Refrigerator Expert? Answer questions, earn points and help others
