Question about Concept CM-1100DR 11.2 in. Car Monitor
The screen turns blue durring a movie
Our cm-1000 dr monitor mounted in our car intermittenly turns blue during a movie. Sometimes the movie can be playing for 10 minutes and then the screen turns blue. Other times the movie may be playing for a hour or more before the screen goes blue, the sound is playing fine durring the period that the screen goes blue and the movie does not stop. Usually, we can just turn the monitor off and then back on and the screen comes back on, but lately it has gone blue and we can not get it to come back on.
As far as I can tell the connections are good. We tried a different DVD player with the same results
Any sugestions?
Thanks,
Tod
  • tdlord Aug 06, 2008
    we have had the unit for about 4 years
    The problem has gotten progressively worse over a 8 month period
    Genius:
  • 1,665 Answers
TV must have a cold solder or bad connection in one of the main boards or in the power board . it will be a real pain for the repairman to fix this. in most cases he needs the tv all the way broke before he can find the problem.
Posted on Aug 06, 2008
    Genius:
  • 1,226 Answers
It probably the connection towards your video from the player got error. But most like this, that is the symptom of the lcd when using defective cable to the PC. Since you use DVD player and at start it display correctly, then there is a parts in the circuit board of the monitor in which when the voltage pass through could not produce the correct voltage drops and will output blue in the screen of the monitor.
If this not loss cable connection, then you should verify and test the circuit board of the monitor.
if still warranty then; avail the warranty is recommended
melnavz
    Genius:
  • 2,028 Answers
This will most likely be with the video jack on the monitor. You might try to take the cover off the monitor and check to see if the jack has a loose or broken wire.
Posted on Aug 05, 2008
  • Ryan Rogers
    Ryan Rogers Aug 06, 2008
    This is definitely an internal problem. Since the screen works somewhat, I'm going to say the jack or the wire/cable that leads from the jack to the screen has come loose or is damaged by corrossion. Check the jack and wire/cable inside the unit.
  • 4,472 Answers
It sounds like it is an internal problem. Could be bad ribbon connection or something else that is loose. How long have you owned the unit for?
Thanks,
Lee
  • Lee A.
    Lee A. Aug 06, 2008
    Then your best bet is most likely to replace the unit. If you have a moment I hope you will reconsider and accept and rate my solution accordingly.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 03, 2008
    I would really be interested to hear what you did to solve the problem? I gave you the best solution if you needed any further assistance I would have been more then happy to answer any questions.
    Thanks,
    lee
Ive got the screen hooked up to my lap top everything looks great but when i play a movie the screen flickers
Screens will flicker during movies if the monitor settings or drivers are incorrect.
Check to make sure that the drivers for that model monitor are installed and up to date.
Go into control panel>display>settings>advanced>Monitor
and try changing the screen refresh rate (Hertz). You can also adjust the resolution from the settings screen as well.
Dec 21, 2009 | LG W2353V-PF 23' LCD Monitor
30 inch philips tv 30pf9975 /17. Gets sound but only blue screen through component hookups. Sometimes works all day but intermittenely gets blue screen.
dear i think there is a fault in your moniter cable means the two cables red and green is broke down or damage inside the plastic cotted wire.sometime when u move the wire the broken ends of the cable meets and u get clear result but when they disconnect u get blue screen
Nov 05, 2009 | Philips 30PF9975/17 Monitor
PS3 Turns Itself off and wont turn on
sorry mate i cant fix it but my buddy has a problem with his also
his ps3 freezes even in the menu screen and during video chat it shuts off
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Vertical Tilt on Screen & Occational Blue Spot
firstly check the 1000micro farad near the ic vertical,u have to change it.
secondly for the blue green change the positor,if you dont know where it is!!!! it the near the degassing plug
Apr 20, 2008 | Sanyo DS24425 24" TV
Shutdown during exciting audio
check the wattage of the speakers, they could be drawing too many watts from your amplifier, if you plug in a speaker that's more than the channel, it could harm your amp.
for example a 200 watt stereo, with 4 channels that equals 50 watts per speaker.
Hope this helps you out
Apr 01, 2008 | Audio Players & Recorders
Dvd movie playback
Techies may be right- the only way to find out is to get a cool breeze around the unit- a fan say- whilst in operation.
Jun 07, 2007 | Panasonic SC-HT720 System
The blue light of the monitor keep flash and no picture appears on the screen
I have exactly the same problem with my Medion 17" TFT monitor. It is not the video card (tried changing it) or the motherboard. Fitting a different monitor makes the problem go away. The monitor does not display the "No Signal" message when unplugged from the PC either. It must be a fault in the monitor, and as it seems to be a design fault. I suggest you contact Medion and nag for a replacement.
Dec 06, 2006 | Medion MD 7317 17" Flat Panel LCD Monitor
My monitor remains black
well your screens broken mate the only thing you can do is get a new one
Sep 30, 2006 | Amptron CMV-922D 19" Monitor
Concept CM-1100DR 11.2 in. Car Monitor Logo
199 people viewed this question
Top Concept Car Audio & Video Experts
jamie suver
Level 1 Expert
Robert Rankin
Are you a Concept Car Audio and Video Expert? Answer questions, earn points and help others
