Question about Vtech DECT 6.0 Digital Cordless Phone
We have 2 Vtech cordless phones -a 6.0 and a 5.8 I don't think either work when the power goes off. Can't even phone the Power co.. Is this normal ?
    Problem Solver:
  • 8 Answers
Yes, that is normal for all cordless phones. they are really just a radio that sends a signal from the base/charger to the cordless hand set. when the power goes off the base does not work at all. Go buy yourself a cheap corded phone, and when power goes off plug it into any wall phone jack and then you can make calls.
Posted on Apr 04, 2011
Why do my VTech phones says outer range or no base on both of my phones
Out of range OR No power at base is shown in the handset ...
www.vtechphones.com/support/.../353
VTech Communications Inc.Out of range OR No power at base is shown in the handset display window. Why don't ... Tip 1 of 5. Confirm proper installation of the telephone base and charger power adapters, and handset battery. You should only use the VTech power adapters provided with your telephone. ... Next Tip This solved my problem. Tip 2 of 5.
FAQs - VTech Communications
www.vtechphones.com/.../frequently-asked-...
VTech Communications Inc.Have a question about VTech cordless phones? Visit our ... How do I find my model number ... My battery pack does not last very long between charges.
VTech CS6429-4 DECT 6.0 Expandable Cordless Phone ...
Jan 08, 2016 | Vtech Lands Phones
How do i program a 6.0 detz phone to a 5.8 cordless base
contact V tech website for technical support but do not think it will work
Apr 02, 2015 | Vtech DECT 6.0 Digital Cordless Phone
My Vtech detct 6.0 is displaying a No line message. I tried moving it to a jack that I know is working but it still has the same message. There is no dial tone and no incoming calls.
The battery detect circuit of the cordless phone has failed. "Battery" is the 24VDC signal
sent by the CO (Central Office) to each telephone that goes off-hook.
Fix: get the phone serviced (hopefully under warranty), or replace.
Jul 16, 2011 | Vtech Cordless 6041 Phone
My phone vtech dect 6.0 has on the display not registered.
My Dear:
May 06, 2011 | Vtech DECT 6.0 Digital Cordless Phone
After power cut the phone will not connect,it just keeps reading searching in the screen no dialing tone,the line appears ok as a normal plug in phone works ok can you help many thanks. I cannot find the...
I think if you switch off by holding down the 'exit' key for about 10 sec, then switch on again (same key) it might recover. Mine did, but seems to need the process repeating from time to time. When switched on again it still has to search for about 5 minutes.
Jan 07, 2010 | Vtech Digital Cordless Telephone VT-2568
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
May 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Vtech cordless phone/ detc 6.0
This worked for me. Unplug the power to the base for 10 seconds then plug the power back in. That did it for my "connecting....." problem. Good luck!
May 19, 2008 | Vtech Cordless 6041 Phone
Vtech 5.8 GHz and says cant connect
Mine turned out to be not getting power from the surge protector.  Plugged it into the wall and it worked again.  If the power light is off to the base station it is not getting power and won't connect.  I know this is a duh, but I missed it.  Probably not what is wrong with yours.
Nov 19, 2007 | Vtech 5.8GHz Analog Cordless Phone
Vtech 1p8100 wont come on
Vonage told me the power supply was bad. I said it mesures 5 volts how could it be bad? reply - "I dunno thats what they told us to tell you". I powered it up with a 6 volt "wallwart" and it works fine.
Sep 06, 2007 | Vtech IP8100-2 Twin Cordless Phone
Vtech DECT 6.0 Digital Cordless Phone Logo
266 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
