Question about Mitsubishi WS-55809 55" Rear Projection Television
Hi, my tv have multi color picture, started last night and changes to rainbow colors also you can see duplicate copy of a person head the time the channel, can you advise what is the problem, it is a Mitibushi tv 1080 and some time at the bottom of the tv they are bow shape color lines Thanks, Praaksh
  • 1 more comment
  • pgawrinauth Apr 04, 2011
    Hi E-Guru,
    Can you advise if the convergence power supply board is the same as the v17 or v18 series convergence repair kit, since i can order and replace this part since it comes with a cd to show replacement procedures.
    Thanks,
    Prakash
  • pgawrinauth Apr 07, 2011
    HI, I GUESS MY TV IS NOT A 55809 MODEL, I ORDERED A CONVERGENCE FOR THE 55809,
    WILL THIS WORK ON MY MODEL WHICH IS A WS-65511 OR I HAVE TO ORDER A CONVERGENCE FOR THE WS-65511, PLEASE ADVISE.
    THANKS,
    PRAKASH
    Hi ,
    NOTE MY TV IS NOT MODEL WS-55809, I ORDER THE CONVERGENCE PART FOR THIS MODEL WILL IT WORK ON MY MODEL WHICH IS A WS-65511 OR I HAVE TO ORDER A CONVERGENCE FOR MODEL WS-65511 TV IS HAVING MANY COLORS & BOW SHAPE, IF I HAVE TO ORDER A CONVERGENCE FOR MODEL WS-65511 WHAT WILL BE THE PART NUMBER CAN YOU PLEASE ADVISE.
    THANKS,
    PRAKASH
    Brigadier General:
  • 3,917 Answers
Hi
The problem is in the color convergence power supply. With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The convergence power supply board is in the upper-right hand. You need to replace or repair this board. If you are not able to do it by your own seek help of a repair person.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 04, 2011
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
I own a color TV 29 '' model CM29 FS1 The color display on the screen shows Multi-colors instead of plain Blue. The Multi colors continued to remain on display even when the picture on the TV / DVD comes...
Hi! the problem you have describe denotes that you have a defective positive thermistor. the positive thermistor is the one responsible in turning on the degaussing coil to align the stray color on the picture tube during start-up.
Jul 11, 2009 | Televison & Video
Rainbow screen, no color, tv fell over
ur tv needs to be degaused using a degausing wand or ring. mos def needs to be taken to a professional to be done.
May 18, 2009 | Zenith SY2765S TV
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
TV problem
I have a Mitsubisi TV receier moel c204701536
I have a cable but channals from 29 to 59 do not work the rest id fine.
Apr 02, 2008 | Televison & Video
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
Apr 08, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
