Question about RCA P52926 52" Rear Projection Television
Hey can you help me please
Hey the ic burn and i have lost the number of it
    Champion:
  • 230 Answers
Give me the location part number ( inside chassis) and model number, I will help you soon. Thank you
Posted on Aug 13, 2008
6ya staff
SOURCE:
Bose burned Integrated Circuits
I have the same problem here, this IC is shorted, is made by International Rectifier, it must be a inverter IC the number printed should be a ghost number because I can't find it, maybe BOSE ask IR to put a nonexistent number to block people fix it, the number by the way is P834 HA1M1 here is a photo also, if someone knows about which other number works here let me know please
Aug 13, 2013 | Apple Bose SoundDock Series II Digital...
Sony ericsson EP800 USB+5V charger IC SO8 is burned and I can't detect the part number
Just get another on EBAY. It's not worth messing with versus expense. Ya, it probably could be fixed, but hard to find a schematic for it.
Dec 10, 2012 | Sony Ericsson EP800 Power-Saving...
SIR, WILL YOU PLEASE LET ME KNOW THE NUMBER OF THE IC802 IN THE POWER SUPPLY,BECAUSE THE EXISTING IC 802 BURNED BEYOND RECOGNIZE
Unfortunately not. If you are talking about what i think you are talking about, then you will not be able to find that number if it is burned away. That number is either a unique production batch number or a manufacturing date, either way, if it is burned beyond recognition, then unfortunately, that number is forever lost. If you are searching for a replacement chip, however, i have found one online; you can use this link http://www.donberg.ie/catalogue/semiconductors/semiconductors_tda/tda_16846.html
Feb 16, 2011 | LG Flatron L1718S LCD Monitor
Television has double images like 3D, and bottom half of screen has a concaved image.
Please replace convergence ICs in tv, there are two big black ICs that has number STK392-110 mounted with big aluminum heat sink, replacement these ICs will solve your tv problem. Also check big resistor nearby these convergence ICs and replace if found burn mark or color faded.
On circuit board, IC location number is IC7001 and IC7002
Let me know if you have additional question.
Thanks.
Dec 25, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Burn resistor
if its a 4 band resistor, use the following calculator...
http://www.dannyg.com/examples/res2/resistor.htm
if the resistor is a 5 band, use the following link....
http://www.sizes.com/materls/resistorcolor.htm
hope this helps!
Jun 16, 2008 | Dell E773C 17" CRT Monitor
OUTPUT IC REPLACEMENT
Original number is PAL007 or PAL006
As replacement you can use TDA7384 the only problem if you use the this ic,the pwr REMOTE WIRE will not work because this pwr line came from the pin number 25 of the pwr output ic.
If you using external amplifiers you have to modify the remote line or use an external switch for the amplifiers.
Jan 21, 2008 | Pioneer Premier DEH-P960MP CD Player
Problem
deko, heres the number for Sanyo parts, 800-877-5032, you can order the service manual there, part number for manual is KTDS27425. I`m sorry I don`t have it to look up the IC but it will be very usefull to have the manual, I think it`s around $20.00
good luck with it, BMW Rider
Jan 14, 2008 | Sanyo DS27510 27" TV
Part number for IC module Hitachi 50EX12BA?
The Hitache 50EX12BA uses 2 IC's labeled STK392-110. If you are looking in the back of the set, the convergence IC's are mounted on the large heat sink on the right side. If one of the IC's has burned out, go ahead and replace both IC's with the newer improved STK392-150 IC's. These IC's are very common and can be ordered from almost any electronics parts supplier. When installing the new IC's you will need to clean off the old heat sink compound and apply fresh compound to the back of both IC's.
Aug 18, 2007 | Hitachi 50EX01B 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
