Question about Ovens
Bosch Oven hbn 131 1.0 B stopped working yesterday. The only change is that had used the grill function earlier in day after a very long time due to toaster no longer working. I have changed the 13 amp fuse at socket in wall. Grateful for any advice on how to get things back up and running. Y
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    jmgldsmth
    • 1906 Answers
    SOURCE: what's the power output of the Bosch HBN 43R550B oven
    220volt 50amp
    Posted on Apr 22, 2009
    barkencoa
    • 3463 Answers
    SOURCE: oven turns on but does not heat up
    If fan is working o/k, then you need to fit a new oven element.
    Please rate my solution.
    Thanks.
    Posted on Aug 27, 2009
    reddyanantha
    • 205 Answers
    SOURCE: HBN 56M5.1B oven and grill not working
    hello mam please call the engineer and make him to check the programmer.and for loose connections.
    Posted on Oct 04, 2009
    HBN 5605.0B power failure
    Unplug the oven , then ohm out the heating eliment. My guess is that it is burned open.
    Jul 13, 2014 | Bosch HBN 430560B / 430520B Single Oven
    Bosch HBN 91 Sticky Fan
    Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
    Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Function selector knob loose
    contact the bosch service agent for spares
    Sep 03, 2017 | Bosch Ovens
    Schematic for Bosch HBN 131 550 Oven Required
    As with most appliances these days therer is a tech sheet somewhere inside the oven, not in the cavity itself but most likely behind the control heading. If its not there you may have to search a little, and as long as no one else has worked on it you should be ok. I only say that because techs have a bad habit of walking off with the tech sheet, some on accident, some on purpose.
    May 11, 2012 | Nokia N Cell Phones
    My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
    Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
    Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
    My bosch oven grill element is not working and my oven does not seem to be getting as hot as it should. any ideas what it could be.
    More than likely the grill element has failed, and this could account for the oven not getting hot enough, as on some makes, the grill element is on at the same time as the oven element, so if the element has failed, then it will not be hot enough.
    My advice would be fit a new grill element, and this hopefully will solve the problem of the oven not being hot enough.
    Thankyou.
    Jan 25, 2010 | Bosch HBN 430560B / 430520B Single Oven
    I have A Bosch HBN32 oven which has just stopped working all the timers are switched off and the grill still works but the oven only heats up to about 80c the fan still works. any help would be greatly...
    ck wiring ( tec sheet inside the panel - there on most bosch a one time thermo / or it may be a resetable one .but you will have to reset it by pushing the red button . this may correct problem . if it does it again look for a over heating porblem like the ( fan foing too slow. ) or temps prob problems. .. mm / hope this helps / feed back pls /
    Dec 20, 2009 | Bosch HBN 3550 Electric Single Oven
    Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
    NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
    Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
    Bosch electric single oven (hbn 4305)
    Dec 08, 2007 | Ovens
    Fan oven not heating, bosch hbn 202t
    the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
    May 04, 2007 | Bosch HBL 5032 Electric Single Oven
    Ovens Logo
    413 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
