I just did a full factory restore of Windows XP yesterday. After the install was complete I enabled the XP firewall and loaded my USB adapter software into the computer. After going through all the steps, such as entering WEP key and pass phrase I checked the Windows monitor and It said said that I was connected to the wireless network with good signal strength @ 54Mbps. So at this point I went to All Programs and clicked on Windows Update to start loading everything back on the computer that was removed via the restore. But when I clicked on Windows Updates a window popped up that said: "The web page you requested is unavailable offline. To view page click connect." So I clicked connect, and it said: No connection to the internet is currently available". Any idea what needs to happen in order to connect?
  • 24 more comments
  • artlutherie Apr 04, 2011
    OK, give me about 20 minutes
    Autoconfiguration IP address: 169 254 18 225
    There's no defauly gateway number
    And when I typed in ping wwwgoogle.com it said "ping request could not find host. check name and try again"
    It'a Netgear wireless router that I'm connecting to. We have a laptop that connects to the same router. I'll go check to see if it's connecting.
    OK, the laptop works fine. Also, I checked my computer and it's only at 1 Mbps but still good signal strength.
    I'll check the passkey. Your talking about the WEP key, right?
    I just entered the correct WEP key and pressed enter and a little message came up from the little computer icon (at the bottom right hand side of the monitor) that said "windows was unable to find a certificate to log me onto the network jpas111".
    When I click on Available Wireless Networks, there's only one available network, and it is our network, and it's selected.
    When I right click on the wireless connection icon and select Available Wireless Networks I get a window. at the top of the window it has: Connect To Wireless Network and at the bottom, on the left side it has a clickable Advanced icon and on the right it has a clickable Connect and clickable Cancel icon.
    It's obviously not the same window that you show. I have seen that window though but it was before the computer was reset to factrory settings via a windows reinstallation.
    Your probably going to scream but when I click on Properties, I get a greyed out Wireless Network Properties window with no Authentication tab... just an OK and Cancel tab and a few boxes that can be checked and unchecked.
    It wasn't checked
    OK, I'll let you know how it goes. It'll probably be tomorrow around the same.
    And I can use a recordable CD-R for the service pack right?
    And how come I can't see my replies I can only see yours?
    Anyways, if for some reason we don't get back in contact: Thank you
    Alright, I have SP2 installed.
    Now I can see the window you have linked above..
    When I click on Authentication (from your directions above) a window pops up that says jplas111 properties. And the window is greyed out so that I can't uncheck the second box. The other two boxes are unchecked though.
    Not sure if my last reply went through so I'll try another way.
    SP2 is now installed and I can see the window that you have linked above.
    When I click on the Authenticate tab a window pops up that has jpas111
    properties at the top. And the window is greyed out so that I can't uncheck the
    second box. The other 2 boxes were already uncheked though.
    The box is unchecked and I restarted the computer. Now the little wireless icon says: Acquiring Network Address. And it has a little yellow ball moving around it - that it didn't have before
    Ok, I'll connect it with a cable to the internet but it won't be until tomorrow.
  • artlutherie Apr 05, 2011
    Will the remote support session work wireless? Because before I uninstalled Windows I used to be able to get online by doing system restores. But when I would turn the computer off for the day and back on the next day I would have to do another restore to get back online.
    Also, I have the latest SP3 on disc. Do you think I should go ahead and install it onto my computer?
    I just installed SP3 but now SP2 is gone and so is the wireless icon. I backed up SP2 yesterday when I installed it but can't fine it in anywhere. Should I reinstall it?
    What are the cables called that I need and where do I buy them?
    We have a Motorola modem and a Netgear router.
    Do I have to hook cables to both the modem and the router?
    I just need one? And it plugs into the ethernet input on the router right?
    Office Depot or Staples likely to carry it?
    Ok, it's hooked up, how do I get online?
    Dell Dimension 8200
    Will you still get paid if I switch to another tech? Or is that even an option? If not, we can end this. I do agree you've done way more than 5 bucks worth.
    where do I get the PNP id's from?
    Here's one of them. If this is what you need I can send the rest. Is there any way I can pay you more?
    Ethernet Controller PCI\VEN_8086&DEV_1229&SUBSY the drivers for....
    Any way I can get the other three drivers on my own to save you the work?
    I copied it to CD and put in my computer to install but Windows couldn't open it.
  • 13,433 Answers
You should be online if your wireless router is connected to a modem or it is the modem and you have paid your bills.
To gather some details, hold down the windows key and press r, then write cmd on the run window and click ok.
in the black box write ipconfig and hit enter look for your ipadress and default gateway, write them here.
next write ping www.google.com and hit enter. let me know what it tells you.
Posted on Apr 04, 2011
  • 26 more comments
  • Ekse Apr 04, 2011
    there is no rush, you have 7 days and each time you post a message you get 7 days from that message.
  • Ekse Apr 04, 2011
    your connected wirelessly to something, but that device is not connected to internet or is malfunctioning.
    Restart the wireless station that you are connecting to --- no I don't mean your computer, the modem or router that you connected to. Its not working or not connected to internet.
  • Ekse Apr 04, 2011
    other possibility is that you entered the wrong passkey. its normal for it to let you connect but it wont work, until the correct passkey is given.
  • Ekse Apr 04, 2011
    yes
  • Ekse Apr 04, 2011
    Okay the wireless settings are wrong, open the wireless networks from the botton right of your screen, or right click on the wireless connection icon and select show available wireless networks.
    picture:
    http://www.microsoft.com/library/media/1...
    in the wireless network list window, on the left side click on change the order of preferred networks.
    picture of the window:
    In the new window that opens after you click on CHANGE THE ORDER OF PREFERRED NETWORKS.
    Click on your network from the list and click on properties.
    on the top you will see Authentication. Click on that. And then remove all the checks from the checkboxes on that page and apply and then ok. then connect again and it should work.
  • Ekse Apr 04, 2011
    Could you follow the instructions to the letter. From the left side click on change the order of preferred networks. THEN on the new window that opened Click on your network from the list and click on properties from below.
    On the new window that opens you will see Authentication Tab at the middle - top. Click on that. And then remove all the checks from the checkboxes on that page and apply and then ok. then connect again and it should work.
  • Ekse Apr 04, 2011
    okay I see you have the original windows xp, that window comes after you install Service pack 1 I think or service pack 2. So in your case, sorry I have not used a windows xp computer so" old "in a long time.
    Hit advanced.
    after you have done so do you see this?
    http://www.shoreline.edu/info/xpwire.jpg
    from there it should be the same. select your network from the list and click on properties.
    should work.
  • Ekse Apr 04, 2011
    is this what you see
    https://help.csufresno.edu/students/imag...
    Remove the check from the Authentication shared mode
  • Ekse Apr 04, 2011
    if that doesn't work I need you to download the service pack 2 with your other computer that works, put it on a memory stick or similar transfer it to the problem computer and install it after restarting the computer the pages will look as I showed on the first pictures.
    http://www.microsoft.com/downloads/en/de...
  • Ekse Apr 04, 2011
    okay, see the comment I posted 5 seconds after yours.
  • Ekse Apr 04, 2011
    I'm not sure about the comments, I see them all. maybe you need to hit on View additional comments.
    Yes I will be available tomorrow the same time, as I said in my first message you have 7 days until the thread closes. But I would appriciate a additonal comment or a accept if the problem is solved before that.
    Thanks and good luck, if you need anything I'll be here and respond as soon as I can.
  • Ekse Apr 04, 2011
    I found a short guide about this
    http://helpdeskgeek.com/how-to/windows-w...
    make sure the firts box, about authentication is unchecked.
    restart the machine and you should be online.
  • Ekse Apr 04, 2011
    I did get it, sorry I'm not constantly on the computer so please allow me time to respond.
  • Ekse Apr 04, 2011
    if the problem continues let me know, connect the computer with a cable to the internet and we will start a remote support session and I'll sort it out for you, just let me know.
  • Ekse Apr 04, 2011
    ok tomorrow sounds good
  • Ekse Apr 05, 2011
    install it, and the remote support is pointless over wireless if we are trying to fix wireless problems.
  • Ekse Apr 05, 2011
    The system restores do more harm than good in such cases. Install sp3 and all the things will be there. Don't restore back to sp2. And then if you could connect with a wire I can assist you over remote support.
  • Ekse Apr 05, 2011
    You need to connect your computer to the wireless router with a cable then I can help you over remote support to solve the wireless problem. The router and the modem should already be attached to each other with a cable.
  • Ekse Apr 05, 2011
    oh the cable is typically a Cat 5 network cable http://www.amazon.com/Belkin-CAT5E-Patch...
  • Ekse Apr 05, 2011
    yes and the other end goes to the port on your pc
  • Ekse Apr 05, 2011
    Probably, we don't have those two over here so I don't know.
  • Ekse Apr 05, 2011
    Are you not online? If not, then the drivers for the computer are not installed. Could you tell me the brand and model and I'll find them for you, you have to use another computer to transfer them to the problem computer. Alot of work for 5$....
  • Ekse Apr 05, 2011
    Thanks, dell has 3 different drivers available to find out which one is the correct one for your machine, hold down the windows key and then press r, write msinfo32 and hit ok, on the left side open components and then find problem devices now on the right side, could you Copy and paste all the lines of text from there to here. To copy select one item or line, then press CTRL+C then come here and in the text box write 1: and then press CTRL+V to paste it here. If this is too much you should consider taking the machine to a local repairer who can install all the drivers for you and take a look at the wireless problem, I'm doing much more than I should for the 5$ that I will get out from this.
  • Ekse Apr 05, 2011
    No I won't. If you could send me the PNP id's from there.
  • Ekse Apr 05, 2011
  • Ekse Apr 05, 2011
    here is the driver for the ethernet adapter
    http://support.dell.com/support/download...
    Download
    1.Click Download Now, to download the file.
    2.When the File Download window appears, click Save this program to
    disk (Windows XP users, click Save) and click OK. The Save In: window
    appears.
    3.From the Save In: field, click the down arrow then click to
    select Desktop and click Save. The file will download to your desktop.
    4.If the Download Complete window appears, click Close. The file
    name icon appears on your desktop.
    Install
    1.Double-click the new icon on the desktop labeled R48857.EXE.
    The Self-Extractor window appears.
    2.Click OK or Continue.
    The Self-Extracting Driver Installation window appears and prompts to
    extract files to C:\DELL\DRIVERS\R48857.
    3.Leave all of the default settings and click Unzip or OK. If the
    directory doesn't exist, you'll be prompted to create one. Click Yes. A
    Self Extractor window appears and indicates C:\DELL\DRIVERS\R48857 files were
    extracted.
    4.Click OK.
    Follow the on-screen installation instructions in the window.
  • Ekse Apr 05, 2011
    are you still not online?
    they are all at http://support.dell.com/support/download... under network
    theres alot of items there, the drivers will read Driver, there are tools and other programs also that you don't need.
  • Ekse Apr 05, 2011
    The driver may need to be installed by hand. to do that right click on my computer from your desktop or start menu and select manage........................ Then On the computer management window on the left side click on Device manager ............... Then, on the right side, you should see devices with yellow ? marks, find ethernet adapter from there and right click, update driver., now you need to Look for the drivers yourself - Browse for drivers or driver software on your computer. (if asked do not use windows update) Now include the folder C:\DELL\DRIVERS\R48857 and then hit next it should find the driver and install it after which you should get online. if not, go and open my computer then the C drive, then the dell folder then the drivers folder then the R48857 folder and look for a setup or install program there.
I use a D-Link DWL-G122 USB Wireless adapter on my laptop, but I recently upgraded to Windows 7 and now the driver which was more for Win XP doesn't work very well. Is there a newer driver that is for Win...
you can try to see if there is a Windows & driver for your Air Plus adapter at the D-Link site if not use the windows compatibility feature to load the drivers for you device.
2. you can also use this feature :
Install and use Windows XP Mode in Windows 73.check the windows "help and support" link under the Orb in Windows 7 to get full instruction set to install and use Windows xp mode in Windows 7.
Apr 24, 2011 | D-Link AirPlus G DWL-G122 (DHDWLG122)...
When I try to boot up it says windows did not start properly and it just keeps rolling this screen. It flashes to the windows xp for a second and then goes back to the screen saying it did not start...
Try restore pc to factory setting. here is the way : http://support.gateway.com/s/software/microsof/Vista/7515910/7515910su12.shtml
Or follow this without picture is the same info:
Restore from Factory Default
The Factory Default installs a new copy of Windows Vista™ on the computer. The installation restores the computer back to the factory installation of Windows Vista with all the drivers and programs that originally came with the computer.
Notes:
  • Be sure that you back up your data files before performing this option. All of your personal data files and applications are erased during the recovery process.
  • Due to the large number of virus and Spyware threats on the Internet, it is recommended that you disconnect all Internet connections before performing the recovery. After the recovery, antivirus and firewall software can be installed, and then the Internet connection can be re-enabled to update the antivirus definitions and perform Microsoft® Windows Updates.
  1. Remove all CDs or DVDs from the optical drives.
  2. Turn off the computer, using the normal Windows shut down process.
  3. After the computer is turned off, disconnect all USB devices except the keyboard and mouse. This includes USB devices such as a printer, scanner, removable storage, or camera.
  4. Turn on the computer. After the Gateway BIOS logo appears, press ALT+F10. The easiest method is to hold down the ALT key and repeatedly press the F10 key. Note: There is no prompt to press Alt+F10.
  5. Windows loads files.
    View Picture
  6. The Please wait a moment screen is displayed.
    View Picture
  7. In the Restore from factory default dialog box, click Next.
    View Picture
  8. In the Destination Disk Information dialog box, click Next.
    View Picture
  9. In the Notice dialog box, click OK.
    View Picture
  10. The hard drive partition is created.
    View Picture
  11. The factory default installation is copied to the hard drive.
    View Picture
  12. In the Finished dialog box, click OK.
    View Picture
  13. The Please wait a moment screen is displayed and the computer restarts.
    View Picture
  14. Windows prepares to start for the first time. This may take a few minutes.
    View Picture
  15. Windows continues setting up the computer.
    View Picture
  16. The computer restarts.
  17. In the Set Up Windows screen, click Next.
    View Picture
  18. In the Please read the license terms screen, select the I accept the license terms check box for each item, and then click Next.
    View Picture
  19. In the Choose a user name and picture screen, enter the appropriate information, and then click Next.
    View Picture
  20. In the Type a computer name and choose a desktop background screen, enter the appropriate information, and then click Next.
    View Picture
  21. In the Help protect Windows automatically screen, click Use recommended settings.
    View Picture
  22. In the Review your time and date settings screen, select the appropriate settings, and then click Next.
    View Picture
  23. In the Select your computer's current location screen, click the appropriate option.
    View Picture
  24. In the Thank You screen, click Start.
    View Picture
  25. Windows checks the computers performance. Depending on hardware, this process can take up to 15 minutes to complete.
    View Picture
  26. Windows prepares the desktop.
    View Picture
  27. The Gateway Recovery Management is installed.
    View Picture
  28. Installation is complete.
Dec 23, 2010 | Gateway LT2001u Netbook
I can't turn on windows firewall. respons message: windows cant running ics service
The Windows Firewall Service not started.
Now to fix:
1. Click Start > Run > Type services.msc
2. Scroll down to Windows Firewall/Internet Connection Sharing (ICS)
3. Double click it.
4. Change startup type to Automatic and Click Start.
5. Click Apply and then OK
6. Reboot.
To reset the Windows Firewall to the factory default state, try this:
Type firewall.cpl in Start, Run dialog.
Click the Advanced tab.
Click the Restore Defaults button.
Click Yes to continue when you see this dialog
Restoring the default settings will delete all settings of Windows Firewall that you have made since Windows was installed. This may cause some programs to stop working.
Alternately, you can use the NETSH command-line to accomplish this:
Open a Command Prompt window and type NETSH FIREWALL RESET
This command resets firewall configuration to default. This provides the same functionality as the Restore Defaults button in the Windows Firewall interface.
or
Try this link @ http://support.microsoft.com/kb/914230
Hope it helps.
Note:- If you PC is infected with Malware & Spywarea that disable you have to clean up your PC first!!
Nov 14, 2010 | Microsoft Windows XP Home Edition Service...
How do i reset my hp computer back to the way i bought it?
factory settings could mean performing a system restore to a previous state of the OS. I'll try to explain how you can perform each one of these methods in the article below.
Restore Factory Settings - System Restore System Restore is the in-built tool of Windows XP and Windows Vista that allows you to roll back the registry to a previous state. Note that it only "restores" previous settings for the registry and Windows system files.
You can use system restore to get rid of spyware, but if system restore does not fix your problem, you'll have to resort to either a clean install of the OS or using your recovery CD/DVDs.
You can read my previous post on how to restore your computer using the System Restore feature. If system restore is disabled, you can read my post on how to enable system restore again.
Restore Factory Settings - Recovery CD/DVDs Most computers come with either a recovery CD/DVD or a recovery partition that is hidden on the computer. This is true for most HP and Dell machines now these days.
If you have one of these, you can access the recovery from within Windows or during startup.
For HP, you can go to Start, All Programs, HP Tools, and then choose HP PC System Recovery.
You can also press the F10 key multiple times during bootup to get access to the recovery console in case Windows is not loading properly.
On Dells, you can access the recovery partition by pressing Ctrl + F11 immediately after the machine is turned on.
Note that all of your data will be lost on the hard drive. Using a recovery CD is not the same as repairing XP. When you repair Windows XP, all of the system files are replaced with the original ones, but your data and applications remain intact.
Restore Factory Settings - Clean Install XP Your last and final option for restoring XP to factory settings is to perform a clean install. This requires having the CD/DVD for the OS. If you only have a hidden recovery partition, you will not be able to perform a clean install.
A clean install basically consists of booting from the original XP CD, deleting all partitions, recreating new partitions, and then installing Windows XP from CD.
It's a fairly straight-forward process and you can read this excellent tutorial for step by step instructions. Again, it's important to note that you will lose all your data in this process.
Oct 05, 2010 | Computers & Internet
How do i put the info from restore disc onto flash drive
Before you start you will need the following:
1. Download & Run WinSetupFrom USB-0.1.1.
2. Complete the setup. The program will start automatically once you have finished.
3. Plug your pen drive into the computer and backup anything important from it as we are going to format it.
4. In the WinSetupFromUSB-0.1.1 window: click Refresh next the USB selection box. The USB pen you have just plugged in should now be visible in the drop down menu. Select it.
5. Insert your XP CD or mount an XP CD Image.
6. In the WinSetupFromUSB-0.1.1 window: click Browse, next to the Windows 2000/XP/2003 Source box, and navigate to the location of the XP Install CD.
7. Now click the PE2USB button.
8. Now Tick the Enable Disk Format box under Format Options and Tick Quick Format and Enable LBA (FAT16X). Also make sure that Enable File Copy is not ticked.
9. Click Start. Click Yes when the pop up asks if you wish to continue. Click Yes again when the pop up asks you if you are sure you wish to continue. When you get the Completed successfully message click OK and close PEtoUSB.
10. In the WinSetupFromUSB-0.1.1 window: Click GO. The Program will now create a bootable windows XP install on your USB pen drive.
11. Click agree to the “SYSINTERNALS SOFTWARE LICENSE TERMS” pop up.
12. Click OK to the “This is Important” pop up.
13. The creation process is now complete: Take the newly formatted USB Pen and place it in the USB port of the target computer and turn it on.
NOTE: You must now read carefully what pops up on the screen as it will provide you with the hot-key (keyboard shortcut key) that, when pressed, triggers access to the BIOS. It is usually something like F1, F2, Delete or Escape.
14. Navigate the BIOS with the keyboard and find the section that contains your boot devices. With your USB drive plugged in, the USB drive should be listed. If it isn’t, your system might not support booting from USB.
15. Assuming that it is supported (as is the case with virtually all modern hardware), promote your USB drive to the primary boot device.
16. Exit from the BIOS configuration, saving all changes.
17. The computer will now reboot. Assuming that you have successfully compiled the bootable USB XP install and that you have successfully selected the USB device to be booted first in the bios a screen should appear which reads Windows 2000/XP/2003 Setup – First and Second Parts . Press Enter. You will now be presented with 2 options. Select Option 1 (first part) for the first stage of the installation process.
18. When the first stage setup completes and system reboots select Windows 2000/XP/2003 Setup – First and Second Parts, then Option 2 (second part) for the second stage of the setup.
DO NOT REMOVE THE USB PEN FROM USB PORT UNTIL YOU SEE THE WINDOWS START MENU
Jul 13, 2009 | Acer Aspire One AOA110-1588 Notebook
Installing XP
Acer computers come with a factory restore partition installed from the factory. The following instructions are direct from Acer's support website:
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
  1. Enter the password created when eRecovery was first started.
  2. Read the on-screen warning and choose Yes.
  3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 18, 2009 | Acer TravelMate 4230 Notebook
Wireless Adapter not working under Vista
Some device may not have Vista drivers or the drivers are still beta and they dont work always perfectly. Check which kind of wireless adapter is present on your laptop from device manager on XP. Then try downloading Vista drivers for your wireless adapter form wireless card factory website, and install them on Vista.
Nov 04, 2007 | Computers & Internet
WIN XP
Windows XP includes a built in firewall. By default, the firewall is enabled (turned on). In order to use your router, you must turn off the Windows XP firewall. Your router already provides a firewall for you so turning off the Windows XP firewall will not make your system any less secure. Follow the steps below to disable your Windows XP firewall: 1. Right-click on "My Network Places" on the Desktop. 2. Select "Properties" from the menu that is displayed. 3. Right-click on the Local Area Connection icon that corresponds to your network adapter. 4. Select "Properties" from the menu that is displayed. 5. Click the "Advanced" tab. 6. "Internet Connection Firewall" will have a checkmark next to it. Remove this checkmark by clicking it once. 7. Click "OK" to apply the change. Windows will ask you if you want to turn off the firewall. Click "Yes" You have now successfully disabled the Windows XP firewall. You are still protected by your router's firewall. You should now be able to access your router.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
