Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Grinder does not run at all. - Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
MY DBM-8 CRUISINART WILL NOT GRIND COFFEE BEANS THE
Posted on Jan 11, 2013
My domestic worker washed the top inside part of my Aromatic coffee grinder with running water. Will this damage the inside electronics?
I don't know your grinder. But generally as long as it remains off until fully dry it won't be a problem. You will have to open it up and let it dry thoroughly, especially the current fuses enclosed in the wires running to the motor. Also you will have to now clean the grinder disks(assuming burr grinder) and dry them
Jan 04, 2015 | Coffee Makers & Espresso Machines
Why when grinder is on finest setting
Did you clean the grinder before using it? Did you run a 1/2 kilo or so of junk beans through to clean out any oil/grease that was in the system from manufacture? How old are the coffee beans? If you grind at a 4 and run it through the drip machine, does the coffee still taste off?
Apr 30, 2014 | Mahlkoenig K 30 ES Grinder
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
Krups grinder 223
what problem do you have?
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
Ids77 electric coffee grinder I want replace fuse how can I open this prodact please.
see this causes and proceed:God bless you
Sep 25, 2012 | Coffee Makers & Espresso Machines
Coffee beans out of message
HI
I hate to tell you this but your grinder is bad. The sensor in the grinder is messed up, and thinks its done grinding after 3 seconds. The grinder will have to be replaced. Sorry
Dec 16, 2009 | Saeco Incanto Sirius Fully Automatic...
Saeco easy...
Your grinder needs cleaning- are you using oily beans and/or storing beans in refrig/freezer? Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out.. After celaning grinder, will need to re-set it.
Jan 26, 2008 | Saeco Royal Professional Espresso Machine
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
738 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
