Question about Samsung RF265AB (258 cu ft) Bottom Freezer French Door Refrigerator
Door chime alarm stopped working when door is left adjar
2 Suggested Answers
  • 884 Answers
SOURCE: samsung side by side refregerator door left open for some time, the door warning chime does not come on
Check the switch just inside the door. If it's not chiming, it may not be switching the fan either.
Posted on May 07, 2012
How do I make the watch stop chiming on the hour?
It seems that most 4 button electronic watches have similar directions. There should be four buttons. Clockwise from top left is the Light button, followed by S2 (Stop), S1 (Reset) and finally on the lower left S3 (Mode). Who knows why they are numbered this way. To set hourly chime Hold down S1 and press S3. When all 7 day flags show the chime is on. When they are off the chime is off. To set the alarm hold down S1 and press S2. Alarm icon will display or go off. Release S1 button and display will return to normal time. Hope this works for your watch
Nov 14, 2014 | Adidas Candy Digital watch
Reset passlock code
Is your Impala a 2000, 2001, or 2002? This seems to be a common problem in those model years...much like its predecessor the GM VATS (Vehicle Anti-Theft System). While the VATS had a permanent (albeit unapproved) solution, no suck workaround appears to be available for the Passlock system. Some websites offer a correction "module" that looks to be a hit-or-miss solution. I did find the following procedure on a forum, and it seems to be reliable. Here goes:
If your car has been sitting while you were at work or home or in the store, and you are coming out to leave, follow steps 1-6.
If you just had the SECURITY SYSTEM lock you out of the ignition system, you will have to wait the 10 minutes for it to reset and allow the ignition control module to interact with the system. Once the 10 minutes have passed from the ACTIVE SECURITY STATUS, follow steps 1-6. Do not try to shortcut this as it wont work.
If it is raining, you can close your door, just not all the way. Close it all the way and open the door latch without pushing the door open. This will keep you dry.
+++++STEPS+++++ 1.) OPEN YOUR DRIVERS DOOR AND SIT DOWN. 2.) PLACE KEY IN IGNITION, WAIT FOR CHIME. (3 seconds is what I usually wait) 3.) TURN IGNITION 1 CLICK RIGHT (TO THE ACC POSITION) AND STOP! Do not continue to ON and START yet. WAIT ATLEAST 5 SECONDS 4.) AFTER 5 seconds has passed, TURN KEY TO ON and STOP, DO NOT CONTINUE TO START YET! 5.) WAIT AND WATCH. With your drivers door open, here is what you will see and hear = Your notification will signal DOOR ADJAR, then the BATTERY light, then the SECURITY light, during which you will hear the chime sound as if you just started the car. 6.) AFTER YOU SEE THE SECURITY light switch back to DOOR ADJAR or Battery, and after the CHIME has stopped, you can turn the key to start and voila!
It has worked every time for me and 5 of my friends. This whole process takes about 20-30 seconds, but it sure as hell beats 30 minutes, as GM refuses to compensate my time lost to their vehicle\'s design flaws.
RECAP: 1.) Open driver door, sit down 2.) Insert key in ignition, wait for chime 3.) Once chime starts wait 3 seconds 4.) Turn key to ACC position WAIT atleast 5 seconds 5.) After 5 seconds turn key to the ON postion and wait for the security light to switch back to Battery or DOOR adjar, and the chime to stop (Do not try to START if the chime is still sounding) 6.) Once chime stops and Security light has passed, You may now complete the turn to START and it will start.
Note: This is not a permanent workaround, but it will buy you some time, I can almost guarantee it will work for most if not all people, almost all the time.
Oct 11, 2013 | Chevrolet Impala Cars & Trucks
Dodge Caravan door ajar chime dings constantly
if the door is not actually adjar, then the senser that says it is needs attention. on mine there were these silver discs in the door jam that needed cleaning every so often (sliding door)
Mar 09, 2013 | Cars & Trucks
Aqualite stopwatch manual
To change the alarm settings on the Aqualite Men's Analog/Digital Watch, press the bottom left "Mode" button until you find the "AL" word next to your alarm time. Then let go of that button. Then press the top right (Start/Stop) button one, two, three, or four times to select your options (alarm on, alarm and chime on, chime on, alarm and chime off)
Jun 03, 2012 | Watches
How do I turn the alarm off on a Athletic Works, AW60442W
I have the AW21312W, which has 4 buttons:
  1. Light (Top left)
  2. Mode (Bottom Left)
  3. Start/Stop (Top Right)
  4. Lap/Reset (Bottom right)
To turn the set alarm off, push buttons 3 and 4 at the same time, the alarm icon should appear or disappear
To turn off the hourly chime, press button 4. While holding it down, press button 2 and the days of the week disappear. The chime is now off. If you want the chime, press button 4 and hold while you press button 2. When all the days show, the chime is on.
Apr 02, 2010 | Watches
Xinjia xj-686 watch can't turn alarm off
I have the same problem with the xinjia-686. These instructions posted for another digital sports watch worked for me.
noavatar_s.gif davidtolond
Rank: Guru citizen.gif jewelry_watches_small.png Expert
Rating: 85%, 400 votes
  1. Light (Top left)
Feb 19, 2010 | Watches
Drivers side door chime and light go off intermittently
The switch in the door is shorting out. I would have the door adjar switch changed.
Jul 16, 2009 | 2001 Volkswagen Jetta TDI
Chime does not work when opening the door after the car is shut off and also when the running lights are left on after the car is shut off. Chime does work however for a brief second when turning on
There is a switch in the latch of your door which is broken. They used to use easily replaceable plunger switches now they have incorporated the switch into the door lock latch mechanism making it more expensive than necessary. I had same problem. You probably also set off your alarm quite frequently as well. If you shut off your car and try to start it after 30 seconds the alarm sounds, it did in my case. Luckily, I had purchased one of those extended warranties as my car was used. I still had to pay $100 but I think the switch is just over $120 this for me covered labor as well.
May 31, 2009 | 2002 Volkswagen Jetta TDI
Open door lite stays on --we cannot lock the car with the remote alarm botton? 2000 ford taurus
You may have a bad door switch. The alarm is usually wired into the door adjar switch amongst other things. If the alarm system is being told that your door is still adjar due to a bad switch in the door jam then it's quite possible that the alarm system will not operate the locks if it thinks the door is adjar in which is also evident by the dome light staying on. Sounds like a switch. If not the switch then I would lean more towards the alarm system being responsible.
Good Luck. I hope this has at least narrowed down your search if not pinpointed it.
Apr 04, 2009 | 1995 Ford Taurus
How to turn off hourly chime on digital watch
If your no-name/no instructions watch has the chime function, try this to turn it off/on:
In regular time mode, hold down the reset button, while you hit the mode button. You should see something on the face appear or disappear. This could be the chime on/off signal. You will have to wait for the regular time to hit the hour to see if this works.
If you do the same but hit the start/stop button instead, the alarm should turn on/off.
The mystery is that you have to go to this third level of button combinations. Who knew these generic watches were this deep.
Mar 30, 2008 | Computers & Internet
Samsung RF265AB (258 cu ft) Bottom Freezer French Door Refrigerator Logo
51 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
