Vornado Circulating Fan
Problem for Vornado Circulating Fan
Motor stopped
By crownscene on Aug 05, 2008
My fan used to start very slowly, when I turned it on the bladeswould be moving ever so slightly, but the fan was making its loudest noise, than after about 5 mins it would go full-speed.  Now it never kicks over.  Is the motor burned out??  Is it worth repairing?
Same Problem
Sep 08, 2008
-   I have an aloha breeze high velocity fan. When first plugged in the blades are very slow to start. after a few minutes it will start working as it should. Should I grease or clean the fan?
-   6962lacey
Best Solution
posted on Aug 05, 2008
Helpful)
jmeredith
Rank: Guru
Rating: 86%, 106 votes
hi,
you can try and oil it, unplug it and begin taking it apart, your destination is the fan motor, dust around the motor and I would recommend using regular automotive 10w30 motor oil on that motor, put some in a small bowl and use a small baster or equivalent and oil around both ends of the motor shaft(where it protrudes from the motor) behind the fan blades and behind it, look closely with a flashlight where the motor attatches to the back guard. try get some oil in there and within the motor housing to the inner bearing areas if possible. My guess is that its sealed from the factory, but you can try, those fans are the best on the market and have a long warranty, heres a link to the manual
http://www.vornado.com/manuals/allcirc.pdf
J
Comments:
Aug 05, 2008
- hi,
looking at other posts, I think you might also have another problem, check to see if the blade assembly has come loose and is rubbing against the motor, the blade assembly may be held on with a small setscrew allen bolt, or snap ring which must be loosed up to reset the fan blades, once you get that loosened , reset the blade so it doesent bind in either direction, and retighten or reset the snap ring.
J
Aug 05, 2008
- hi,
you may have to shim the motor shaft with a piece of tape or eqiuivalent, then reset if the fan assembly, it may be worn down or has lost its adhesion at the compression fitting there, maybe a shot of super glue, or even better JB WELD it
J
Aug 05, 2008
- hi,'
make sure to oil both ends of the motor, it has two bearings,
J
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Vornado Circulating Fan
Questions and Unsolved Problems for Vornado Circulating Fan
Do you recommend Vornado Circulating Fan?
Answer
Answer
Model 280ss fan has started miking noise when running
Answer
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've... (More)
Answer
How do I open Vornado fan (model EH1) so that I could clean fan blades?
Answer
I have a vornado fan on a pedistal that's about 13 years old. Have to twirl the blades manually to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vornado Circulating Fan:
Top Electric Fan Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Electric Fan Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
