Hello! My system model is hp pavalion dv4 series no is 1216tu.I am unable to see anything on the screen.so can u suggest me what is the problem for this??
  • Computers & ... Master
  • 5,159 Answers
There are several possibilities. Can you connect an external monitor to the laptop to check the video signal. Then press Control-Alt-F1 to send the display to the monitor. Check your documentation for the hot-key to enable an external monitor if the sequence doesn't work. (Otherwise, you need to get into Windows to change the display settings.)
If the external monitor works:
1) The screen is dim (backlight or the backlight inverter failed). To check this look very closely at the screen and see if there is any image. Sometimes holding a flashlight near the screen will help you see this. If you see the image, then the backlight is the probable failure. If there is no image, the inverter or the video cable are suspects. The inverter can be replaced fairly easily and can be tested with either a multimeter (that reads high Hz values) or an oscilloscope after removing the bezel from around the laptop. Hold the probes a fraction of an inch apart about an inch above the inverter. With a multimeter, you should see a value of either 1 (above the range that can be interpreted), a value (say 50,000 Hz). If it isn't working, you will see a 0. The backlights can also be replaced but is harder.
2) The video cable from the motherboard to the screen has been damaged by opening and closing the laptop. This can be replaced.
If an external monitor doesn't work, then I suspect your on-board video has failed or has a problem (assuming the laptop appears to have booted at all). First reset the computer. Unplug all of your peripherals. Then remove the battery (and power adapter) from the laptop. Then press and hold the power button for at least 15 seconds. Reconnect the power adapter(not the battery) and see if any of the keyboard and activity lights come on.
You can try getting into the BIOS to check. Turn off the computer then turn it back on while pressing and release F10. If you can see the BIOS information on the laptop's screen, it's a Windows issue. Try pressing F8 in a similar fashion. In the Safe Mode, try uninstalling the video drivers or reverting to last known good configuration. Alternatively, insert your recovery disc or Windows Install disc and press F9 to select boot location. Try to do a system recovery. (Alternatively, press F11 and do a system recovery to the original condition of the laptop.)
I hope this helps.
Posted on Apr 04, 2011
What's HP Pavillion dv4-1313 dx monitor does not come on
SEEMS THAT THE OS IS UNABLE TO BOOT.GET THE INSTALLATION CD AD BOOT THE SELECT REPAIR.
Apr 21, 2012 | HP Pavilion dv4-1140go Laptop
I have win 7 on hp dv4, my dvd drive can't read some dvds
Download and install a CODEC package for your PC this is the problem you don't have certain CODECs installed these make anything invisible to the system without them.
Win 7 CODEC HDTV pack with all the latest CODECs go to www.freecodecs.com download from there problem should be solved.
May 12, 2011 | HP 419320-001 - HP Pavilion dv4000 Series...
I have Hp pavilion Dv-4 2126 tx notebook with build in Finger print reader.My fingerprint scan along with different website/s login info is duly saved with Digital Persona but i am not able to log in to...
my lap hp pavalion dv4 2126tx........
i am working in win 7 os .when the lap is connected with ac charge plugin its working normally....if the ac plug in disconnected lap becoming death slow
Aug 07, 2010 | DigitalPersona DIGITAL PERSONA USB...
Just replaced power supply unit from a 250 watt to a 480 watt and now computer comes on but will go into power saving mode instead of booting up and keyboard doesn't stay lit like it used to.The system is...
Which power supply went bad? The 250watt or the 480watt? If a power-supply goes bad (dies), it generally takes some (if not all) hardware with it.
Jan 05, 2010 | HP Computers & Internet
Hp pavilion dv4-1220us overheating then shutsdown
Sounds like you need to take it in for repairs, clean outs and/or replacements.
This product is known for it's heating issue and power consumption. Maybe the fan is starting to wear out and it's affecting the rest of the system. I would suggest checking the warranty on the system, if it is no longer valid, then I would look for a local tech in the newspaper.
Dec 15, 2009 | HP NB199UA Pavilion Notebook
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
HP dv9208 pavilion laptop screensaver & briefcase not working
Hello there
Call HP or go to chat support and threaten them that if your Notebook wont be repaired you will go to consumer court....
HP's 24X7 chat support...
http://welcome.hp.com/country/us/en/contact/chat_1.html
Feb 18, 2009 | HP Computers & Internet
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
