Question about LG RU-52SZ30 52" Rear Projection Television
Access service menu lg rear projection tv
Hellor, how can I access the service menu of my lg rear projection tv?
  • Anonymous Sep 15, 2008
    RT-52SZ30RB
I want enter the convergent net code
Posted on Jul 13, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Hold the menu button on the remote and the (ok ) button on the tv down simultaneously for 5 seconds.
Posted on Feb 02, 2009
Hold the menu button on the remote and the menu button on the tv down simultaneously for 5 seconds.
Posted on Aug 10, 2008
How do i replace the bulb in an LG rear projection tv RE44SZ21RD
Note: Wear cotton gloves when handling the lamps as it contains mercury.
  1. Remove the access cover behind the On/Off switch at the bottom of the rear cover by removing the 2 screws using a Philip screwdriver.
  2. Behind the cover is a metal box with a handle that protects the rear of the lamp. Remove the securing screws and pull the box with the handle.
  3. Remove the cable screws and pull out the plug.
  4. Remove the lamp clamp screws and lift the lamp
  5. Put the new lamp in place of the old lamp in reverse sequence of the above.
  6. Dispose the old lamp properly.
  7. Reset the lamp timer.
  • Make sure the TV is on.
  • Press and hold Menu button on the TV set.
  • Press and hold Menu button on the remote control at the same time
  • Hold the buttons until the service Menu pops up.
  • Release the Menu button on the remote then on the TV set.
  • Press and hold Enter /Ok on the TV set then press and hold Mute button on the remote control.
  • Hold the buttons until the Lamp Life Hours screen pops up.
  • Release Mute button on remote then release Enter/Ok on the TV set.
  • Press Select twice to confirm the reset of the counter.
Oct 09, 2009 | LG Televison & Video
Picture Quality
Clean the lenses and mirror. - Carefully with no liquid, just a micro-fiber cloth. They can be accessed by removing the front screen.
There are items in the service menu that can tweak color drive and grey scale, but you can really mess up a TV if you do not know exactly what you are doing. You can also do a comprehensive convergence in the service menu.
Sep 08, 2009 | Sony KP-57WS520 57" Rear Projection...
Access Service menu
Hey there!
Its really easy to do, but write down any settings before you go changing them..
1. Turn off tv.
(use buttons on tv for this)
2. Push volume down and channel down both at the same time, and hold them for about 10 seconds, or until the tv turns on.
Jan 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG Rear Projection TV RT- 48SZ40RB
Some say you can reset the timer in the service menu, normally accessed by holding down the menu button on the TV and the mute button on your remote at the same time. Others say you need a special "service remote" to access the timer. I've changed my bulb twice already and have just learned to ignore the amber lamp timer light. A little square of black electricians tape would make it go away!
Nov 03, 2008 | LG RU-52SZ51D 52" Rear Projection...
Re44sz21rd
HI,
All I can suggest is to replace the bulb. I experienced a similar problem after about 2 years viewing when the recommend lamp life was approx 8000 hours (I got to approx 3000 hours). There is a service menu you can access where you can reset the lamp hours time. I have read that if this is reached you must replace your lamp, but you can extended this by reseting the hours.
I have since learnt that a lamp bulb can go at anytime, so it is worth having a spare. Also I have noticed that switching the TV off at the switch (not leaving it in standby helps).
Try this to access the service menu. Holding down the menu button on the remote and the one on the TV for a few seconds. I think the TV needs to be off.
From memory, I think it is option 4 and option 5, then reset the lamp hours to zero
Sep 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Reset lamp timer
Hold the menu button on the TV and menu button on the remote for 5 seconds.The service menu should appear.Select the lamp option and reset lamp hours.
Dec 15, 2007 | LG RU-52SZ51D 52" Rear Projection...
LG Projection TV has dark picture
To do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off.
Jun 30, 2007 | LG RU-44SZ51D 44" Rear Projection...
Accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Dec 06, 2006 | Toshiba 55H70 55" Rear Projection...
LG RU-52SZ30 52" Rear Projection Television Logo
1,905 people viewed this question
Computer Repairing
Computer Repairing
