Question about Toshiba Satellite A60 Notebook
My Toshiba Laptop is not turning on though i charge it. When i click on the power button, i see the lights going green but nothing appearing on the screen. The caps lock or the num lock is not working. Please provide a solution ASAP.
  • 1,179 Answers
Remove the battery and use this laptop on mains/wall power, with the aid of the power brick from Toshiba. As the battery may be giving problems.
Else it may be that the computer system is experiencing severe problems, in which case a computer technician needs to help.
damnor01
Posted on Apr 04, 2011
My toshiba satellite L25-S1194 wont turn on. no lights, nothing. how could i fix this?
Try taking the battery out, plug the computer in, and see if it turns on. Press the "Power" button for at least 20 seconds (and press hard). If that doesn't work, put the battery back in, and do the same thing. I assume no lights appear like its charging (as you said). If this is the case, then you might have a dead charger (wire broke inside, power surge broke the adapter, etc). You may want to try a different charger of the same model (either from your local Best Buy or from a friend). If it does look like its charging, then your laptop's power supply has died (or the motherboard has died). This is a much bigger hardware problem and should be under warranty (or time to buy a new laptop). All data should be recoverable, however.
Jun 19, 2013 | Toshiba Satellite Computers & Internet
Toshiba Satellite A60 wont power up
It looks like some divece in your laptop dont pass POST test. Tech support from Toshiba required
Sep 23, 2009 | Toshiba Satellite A60 Notebook
No singns of life
Sounds as though your ac adapter is bad.But it could also be the power jack where the ac adapter plugs in also.
Aug 07, 2009 | Toshiba Satellite M105-S1021 Notebook
Packard Bell easy not wont turn on
it is not charged or its battery has a loose connection
Jul 22, 2009 | Toshiba A15-S1292 Notebook
Will Not Turn on
Which pin did your husband reposition, I assume it was the one inside the laptop. He may not have connected the power switch cable back in properly when he rebuilt the laptop. Ask him to carefully check all the connections by opening the case again. These sort of repairs are normally carried out by experienced tech engineers. Some dc connectors (the bit that the power supply plugs into) have to be resoldered to work correctly or be replaced completely. The fact that you were able to charge the battery means little at this stage I'm afraid. Let me know if you need more help.
Jun 08, 2009 | Toshiba Satellite M115-S1061 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Laptop toshiba m35x attempts to power up but stalls
It sounds like video card problem. Bring it to a repair shop.
Dec 11, 2008 | Toshiba Satellite M40-S417TD Notebook
Starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
Feb 22, 2008 | Toshiba Satellite A135-S4427 Notebook
My toshiba laptop will not turn on...
Here is the fix my toshiba laptop also wouldent turn on so i call them and here is what you do 1. unplug the laptop
2.take out the battery 3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit) 4.put battery back in 5.plug in laptop 6.try to turn it on
hope this helps
John
Jan 05, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite A15-S129 PC Notebook will not turn on
I have the same problem. What I have found with mine is that if I can get the battery to take just a little charge then I can get it up and running. Here is how I do it. Disconnect AC power leave the battery in and start the laptop. As soon as thing start to run I plug the AC back in and it works fine from there on. Now mine is flashing as well now and I have a dead battery and it will not restart. Something I have noticed thought is it appears that the yellow light is blinking a code. This is what I have come up with. I appears to be flashing 323 as the code or could be 2 shorts 1 long then 2 shorts and then 3 shorts.
Anyone know where to find info on these flashing codes.
Thanks
Oct 30, 2007 | Toshiba Satellite A15-S129 Notebook
Toshiba Satellite A60 Notebook Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
