Question about NorStar Meridian Norstar T7208 Corded Phone
Hi We have Nortel T7208 handsets...on one of the handset the program buttons on the right are not correctly per standard keys is there any way to reset these keys to their default. Ibrar
  • 43 Answers
SOURCE: default volume HANDSET volume on a m7310?
Were you able to get this setup and working to your liking?
Posted on Mar 12, 2009
ynotphone
  • 192 Answers
SOURCE: have 2 t7316e nortel phones...i can hear the other
Look at the bottom of the set that is giving you troubles, check to see if the handset is plugged into the correct spot.
It should be plugged into the Handset jack not the headset jack.
This is a common mistake.
Posted on Mar 25, 2009
consultel1
  • 860 Answers
SOURCE: How do I listen to by mesasges on a Nortel T7208
To access your voice mail messages either press your open voice mail key (if programmed) or enter feature 981.
Posted on Dec 11, 2009
ynotphone
  • 192 Answers
SOURCE: T7208 Nortel Norstar phone system - how to
unfortunately when a message is deleted... it is deleted unless you have a back up
Posted on Apr 08, 2010
consultel1
  • 860 Answers
SOURCE: cant change time and date on nortel t7208 phone
Programming on the nortel system is done on M 7310, M 7324, or T 7316 sets only.hopfully the receptionist station has one of the larger sets.
Posted on Apr 15, 2010
Testimonial: "With clarification that I gave on steps I took and what were results within three questions figured out the problem and solved it. Thank you very muc"
How do I remove Denied in Admin from a Nortel phone handset t7208
It's not so much removing Denied in Admin as it is enabling whatever feature the user was trying to access at that set.
Which was... ?
Aug 11, 2014 | NorStar T7208 Corded Phone
How do you transfer a call on a Nortel t7208?
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
Oct 29, 2013 | Nortel Lands Phones
How do I change the time on my BT T7208 telephone (Nortel Network).
1. Press Feature x x 8463 (x x TIME) you should have Password displayed on your telephone.
2. Enter 22742 (BASIC) or 23646 (ADMIN) you now should have Hour on your display.
3. Now press Change and enter the correct hours using the key pad
4. Press NEXT and you should have Minutes displayed on your telephone, now press CHANGE and enter the correct Minutes.
5. Press NEXT and you should have Year displayed on your telephone, now press CHANGE and enter the correct Year.
6. Press NEXT and you should have Month displayed on your telephone, now press CHANGE and enter the correct Month.
7. Press NEXT and you should have Day displayed on your telephone, now press CHANGE and enter the correct Day.
8. Now you will have ---End of List--- displayed on your screen, you can now press Rls or handset down button to come out of programming.
Feb 28, 2011 | Nortel Business Series Terminal T7208 -...
How do i change the time on nortel t7208
Hi....you need to push "feature" button at the top of the phone, then * * 2-3-6-4-6 (a.d.m.i.n ), then when phone asks for password, press 2-3-6-4-6 again, default, unless someone has programmed a different one. use the template link below, this fits over the row of keys on the right side of phone. push "next" until you get to "date and time", and then with a combination of "show" and "change" you can get to change time . try it and see how it goes. email me at gpeter52@yahoo.com with questions. link is good for other commands as well. good luck
http://www.meridian-norstar.com/3_nortel_meridian_norstar_programming.html
Nov 08, 2010 | Nortel Business Series Terminal T7208 -...
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
May 04, 2010 | Nortel Business Series Terminal T7208 -...
Handset will not work
Try swapping the handset and cord with a working phone. Those handsets are known to loose the transmitters. As for the ringing, have someone make an intercom call to your extenxsion. Do not answer the call...while the light is flashing press the volume up button several times. www.dyna-tech.us
Hope this helps
Mar 23, 2010 | Nortel T7316E 2-Line Corded Phone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Handset does not work, only handsfree, how to reset on T7208
Check the bottom of the set, and make sure that the handset is plugged into the handset - not - handset to the headset jack.
Make sure that the cords that attach the handset are all plugged in.
Take someone elses handset and test to see if it the set or maybe you have a bad handset issue.
Good Luck
Aug 10, 2009 | Nortel Business Series Terminal T7208 -...
Problem with Nortel WLan handset 2210
must drop the whole programing and start from scratch. it called dumping.
Feb 14, 2008 | Computers & Internet
NorStar Meridian Norstar T7208 Corded Phone Logo
23 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
