Question about GE Profile JTP56 Electric Double Oven
Built in double oven GE profile
Oven start to work then shows F 7 and beeps
  • Anonymous Mar 16, 2014
    rbd 245pdt14 double oven wont come on beeps when start is pressed
  • GE Master
  • 13,433 Answers
F7 code is 'shorted matrix or start key' could be due to a problem with the key panel or control.
Posted on Aug 05, 2008
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
Double oven. Top is digital. It has started
You have a stuck keypad or a bad electronic oven control. Try pressing all buttons at random several times each to unstick a faulty pad. If that does not work the EOC must be replaced.
Oct 06, 2009 | GE Profile JTP56 Electric Double Oven
The upper and lower oven will not turn on there is power to it and clock and oven lights work there is an FO red light that comes on and beeps and flashes
Built In Oven Fault Codes
F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
Sep 21, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile JT952 Touch Pad Button Issue
Try this link
Mar 28, 2009 | GE Profile JT952 Electric Double Oven
Ge profile double overn
This is a common problem. I made this fix 2 years ago and it works like a charm.
Jul 19, 2008 | GE Profile JTP56 Electric Double Oven
JTP56 Double Oven Beeping and Display FO Code
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
GE Profile JTP56 Electric Double Oven Logo
221 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
