Question about Whirlpool Gas Dryer Flame Sensor 338906
I have a whirlpool hot water heater FGIF4034T3NOV serial 0417126596. The pilot will light, main flame will come on, and when the main flame reaches the cutoff point, it kills the pilot light also. I have to wait until the heater cools down to relight the pilot. I have drained the heater, taken out the main flame burner, cleaned the thermocouple, cleaned the bottom of the heater, and don't know what to do from here. The heater is good. Don't want to buy a new one for a simple problem. Just can't figure out what is wrong.
  • 20 Answers
Sorry to see you're having problems! Can you contact me directly so I can help?
www.whirlpoolwaterheaters.com/help
Thanks! ~ Chris
Posted on Apr 05, 2011
Richmond gas hot water heater. After I light pilot and main burner why does it flame out in 15 seconds?
If you had to light the main burner manually, something is wrong. Once you light the pilot and it stays lit, the flame heats the thermocouple to open the gas valve and fire the main burner. Either or both of the components you replaced could be defective.
Sep 10, 2015 | Water Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
What is the proper sequence for lighting the pilot on a whirlpool electric light water heater?
There is not pilot flame on electric water heater! It is electric! You just connect it to the proper inlet (cold water main) and outlet (hot water to tap), then connect it to electrical outlet, switch it on and that is all. it should run automaticaly when you open the tap.
Aug 13, 2010 | Water Heaters
Pilot light will not automatically light when hot water is turned on
This is a great unit! Try turning the flow nob to the half way point and the flame all the way to low. Run the hot water tap and slowly turn the flame dial until you hear the unit try to light. Every house is different regarding the restrictions in the plumbing and water pressure. Once the unit tries to light that is your minimum setting. It is best to leave it there.
Apr 05, 2010 | Bosch & Tankless LP Hot Water Heater
Pilot will not relight properly on 40 gallon natural gas hot water heater
The thermocouple needs to be replaced. That is what keeps the pilot light lit. The thermocouple is the little metal probe that sticks up into the pilot flame. Very easy to replace.
heatman101
Mar 25, 2010 | Whirlpool Water Heaters
We dont think our cylinder is on we have just moved in and have no hot water
The question is? I'll assume you cylinder is the water heater, right?
On the heater (water) you will find or see the red controls and a sheet metal cover over a hole. Remove the cover and this is where you light the pilot light. Press down on the red dial and turn it to pilot. In that position you will be able to press the red button . Geyt a long match or bbq lighter, then, holding down the red button dow for a minute or so and place a match or lighter into yhe area where the lines go The flame will catch the gas and lite the pilot if yo simply move your glame around. When the flame catch on the pilot, continue holding the button down for sveral minutes until the buld the flame isheating gets hot. Then release the buton and turn the main dial to on. The main burner should fire up. If not, and the pilot goes out, repeat the process. The bulb in the pilot flame is a thermocoupler that shuts all gas off if it doesn't detect a pilot flame, so hold the button down longer. If the pilot goes out when you release the button, The thermocoupler is no good and needs replacing. Good Luck_Ned_
Oct 31, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
My bosh water wizard 10P pilot light keeps going out.
Very possible the thermocoupler is no good. The thermo coupler is that bulb that is in the pilot flame. It controls the main valve It's not expensive and fairly easy to change out.. Make sure you get no dirt in the cspillary tube hole.brass screw end. The bulb must be just in the flame tip when adjusting. Good Luck, Ned-
Sep 17, 2009 | Bosch & Tankless LP Hot Water Heater
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Whirlpool Gas Dryer Flame Sensor 338906 Logo
239 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
