Question about Dryers
Maytag dryer mde2500ayw timer keeps tripping breaker
  • 59 Answers
YOU HAVE A SHORT IN THE HEAT COILS
Posted on Apr 06, 2011
My maytag wadher model A7300 keeps tripping a circuit breaker. The drain hose fell off the sink, snd it got wet inside the the wadher. Is the motor blown or timer?
More than likely something has been shorted inside by the water intrusion. Anytime a breaker trips it is due to an over current draw situation. This happens when the power is shorted directly to ground causing too much current draw and the breaker trips in order to prevent a fire.
Oct 22, 2017 | Maytag Dryers
MY MAYTAG FRONT LOADER DRYER STOPED WORKING WHAT TO DO
It could be anything from the start switch to the timer or the motor itself. Did you check to see if the circuit breaker tripped?
May 29, 2012 | Maytag Dryers
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
Jul 15, 2011 | Maytag LSG7806A Front Load Stacked Washer...
Dryer keeps tripping breaker
Something is shorting out...the breaker is tripping to prevent your house from burning down. Stop using that dryer untill you get it fixed. You will need to find the electrical fault or hire someone who can.
Jan 22, 2011 | Maytag Dryers
Circuit breaker keeps tripping
If the breaker keeps tripping then there is a short somewhere.. the first place I would look is the heating element probably broke...
heatman101
Aug 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer just turned off in the middle of a cycle and now wont start up????? is there an over heat button on the dryer motor ?????
The first suggestion is to check the circuit breaker in you house fuse box. If the breaker is not tripped this usuallly indicated that the dryer has a failed component link the timer, door switch, or motor.
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer quit working
Check your breaker first and then the wiring. Check power coming from the timer next. With a load and resistance that you had, you could have tripped one of the breakers.Since you have bypassed the thermal fuse, it probably is the timer switch.
Jan 26, 2009 | Maytag PYE2300AY Electric Dryer
You may have a bad motor that turns the drum. Have it checked out. Does your breaker trip when it stops running? Last I would check is the timer of the dryer.
Jan 24, 2009 | Maytag PYE2300AY Electric Dryer
Sde5401ayw keeps tripping breaker
ck the element if the breaker poping as soon as you use heat dead short eather element are wire going to it
Mar 18, 2008 | Maytag SDE5401AYW Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
