Question about Sport & Outdoor - Others
Need to find a transducer for a model SR260 sea ranger depth sounder
SOURCE: Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Posted on Aug 03, 2008
SOURCE: I need a replacement transducer for a Navico DS 200 Depth Sounder
my ds200 has stopped
if i find it only way to replace you can have the removed transducer
cheers colin jewellersbench@talktalk.net
Posted on Dec 09, 2008
SOURCE: Hi, I have a Matrix 12 Sounder and the depth
Ihave the same problem
Posted on Aug 05, 2009
TechnoMarine
  • 132 Answers
SOURCE: furuno 4100 depth sounder shows depth twice what it really is
check your gain setting try auto gain and try manually gaining back to see if it resolves, if yes, send unit in to furuno, if no, ducer is probably at fault.
Posted on Jan 16, 2010
  • 5 Answers
SOURCE: I have a GPS Map 498-depth sounder not working? Ha...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
Posted on Jul 31, 2010
I was told that the Uniden QT-206HP depth sounder will not work thru an alunium hull is this true or false
Hi!
The transducer for your depth gauge will not work through an aluminum hull. A drilled through-hull transducer or a transom mount transducer are your options here.
Just in case you require it, your Owners Manual can be viewed/downloaded at:
http://ca.binnacle.com/pdf/Uniden-QT206-manual.pdf
Hope this helps..
Jun 20, 2011 | Uniden Qt206hp Digital Depth Gauge With...
..no depth reading. Old transducer cable was
Hi, Check for debree on depth sensor under boat. As you said check for fuse(s) Good luck.
Jun 20, 2011 | Garmin 185 Sounder GPS Receiver
My Garmin 498C will not show the contore of the bottom or give me a depth reading. The GPS works and will show me charts but, not the sounder option though.
You need to check to see if the depth sounder transducer is connected or functioning. It might be turned off, the connectors may be bad or the transducer is bad. I don't have the 498 manual in front of me but I think there is a test function under the setup menu. I'd check my connections (the usual suspect) then run that.
Garmin tech support is pretty good/quick. So don;t be afraid to give them a call.
Aug 29, 2010 | Garmin GPSMAP 498C Sounder GPS Receiver
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
May 16, 2010 | Boating
Unable to track the bottom
I think you need to level the transducer. You have it pointed way out in front of you so that when you're going fast it is able to bounce the signal off the bottom and it comes back to where the boat has traveled to. When you're going slow you're bouncing it out in front of you but it comes back up in front of you. Sorry but I can't find a picture of a Garmin transducer. Hope this helps.
Jun 02, 2009 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Depth sounder
the transducer has to be in the water or attached to the inside of the hull if fiberglass with no air between the hull and the transducer. It doesn't transmit thru air.
Mar 12, 2009 | Raymarine Boating
Jul 05, 2008 | Garmin 185 Sounder GPS Receiver
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Sport & Outdoor - Others Logo
73 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
