Question about GE Spacemaker JVM1640SJ Microwave Oven
No instruction manuel for model J VM152H 002 (was installed when we moved_
The microwave was in place when we moved to the house...No instruction manuel was left. Can I get one?
  • primerib Aug 05, 2008
    It also didn't have the probe
    Problem Solver:
  • 21 Answers
The Owners Manual for the GE JVM152H can be found, saved, and printed from this page: Owners Manual
Hope this helps!
Posted on Aug 07, 2008
  • Nancy_GE Aug 07, 2008
    You can order a new probe - GE part number WB27X10178 directly from GE for $101.25 plus sales tax and shipping ($10.95 - $13.95) or from RepairClinic.com for $56.00 plus shipping ($6.46) - no sales tax if you don't live in Michigan.
I have a Singer Juice Giant II but no instruction manual. Where would I find the instructions?
HELLO.
Way out to the problem.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Thanks.
Sep 19, 2011 | Microwave Ovens
Our GE Spacemaker XL Microwave Oven Model JVM1631WB 002 isn't working properly. It comes on, lights up, turntable works but does not heat food. It also sounds very different (loud) when on.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 04, 2011 | GE JVM1631 Microwave Oven
I need to replace a 2002 GE Profile Spacemaker II Sensor microwave. It does not turn on at all, although the keypad (clock & timer) are working. I need one with the same dimensions as it is installed...
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Feb 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
HOW TO UNINSTALL A WHIRLPOOL OVER THE RANGE MICROWAVE. iT IS IN A HOUSE WE JUST MOVED INTO AND IT IS BROKEN. iT IS ALSO HARD WIRED
Since you did not give model number I am providing info for one type of MW that may be similar. If you want specific info for your MW find model number and consult this page: http://shared.whirlpoolcorp.com/product_literature/search.jsp
Otherwise here are the installation instructions I found that you can use in reverse to figure out how to remove your MW.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%20W10238252A.pdf
Aug 11, 2009 | Microwave Ovens
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Manuel
Go to managemyhome.com and register. This is a FREE service. Once registered, go to the "Home Manager" drop down menu and click on the "Owner's Manuals" link. Follow the instructions on the next page by providing your make and model number. Your manuals are listed in a downloadable .pdf format. All you need is Adobe Reader installed on your computer to view. I hope this helps you.
Jan 15, 2009 | Whirlpool MH1150XMQ Microwave Oven
GE Spacemaker Microwave Oven
You can download GE owner's manuals and installation instructions here.
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No installation Instructions or Owners Manuel
Although you gave an incomplete model number, Owners Manuals, Installation Guides, Warranty Guides and Part Lists can be found for the entire MH3184 series on this page: Whirlpool Product Literature/MH3184 Series
Hope this helps!
Aug 05, 2008 | Whirlpool MH3184XP Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
215 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
