Question about Microwave Ovens
Cooks essentials pressure cooker keystone manufacturing model 99740 I need a new control cap that goes on the top cover of the unit the unit is maybe two years old and used twice. The control broke off
  • 121 Answers
SOURCE: I HAVE LOST THE MANUAL
Here is the ink to the manual in PDF form: http://www.qvc.com/man/k/K97438_man.pdf?&cookie=set
Good Luck, RJ
Posted on May 13, 2011
Testimonial: "Thank you for the answer,very helpful"
Gophering
  • 187 Answers
SOURCE: I need a manual for
IF YOU HAVE INTERNET ACCESS, TYPE IN THE NAME OF YOUR MICROWAVE AND MANUAL AND DO A WEB SEARCH! COOKS ESSENTIAL PRESSURE COOKER MANUAL FOR MODEL NUMBER 99700
YOU'LL FIND MORE INFORMATION THAN YOU'LL PROBALLY NEED, BUT YOU WILL BE ABLE TO DOWNLOAD THE MANUAL AND SAVE IT OR ATLEAST FIND OUT HOW TO CONTACT THE MANUFACTURER TO HAVE THEM MAIL YOU A MANUAL!
HOPE THIS HELPS!
MARTIE
Posted on Aug 24, 2011
SOURCE: need a users guide (manual)
Go to Cook's website and follow the steps and you should be able to download the user's manual free.
Posted on Jan 23, 2010
  • 1739 Answers
SOURCE: Cook's Essential pressure cooker missing
Was able to find an on-line Instruction Manual for the Cook's Essentials EPC460 and EPC450 pressure cookers:
http://www.qvc.com/cd/pdf/K14957_Manual.pdf
On the last page the distributor is identified as Tristar Products:
http://www.tristarproductsinc.com/customer/cs.html
Tristar is now distributing the Montel Williams Pressure Cooker and is no longer listing the Cook's Essentials products.
Suggest you try the Customer Service of Tristar by contacting them directly to see if the can advise on a parts supplier.
Second choice would be to see if a part supplied for similar product might be a substitute. Several brands have parts available through this supplier:
http://www.abtecparts.com/pressure_cookers_and_canners.htm
You could also try making an inquiry through this supplier to see if they can locate the part or recommend a substitute.
Posted on Feb 03, 2011
ZJLimited
  • 17970 Answers
SOURCE: cook's essential pressure cooker has
Make sure the inner container is dry... plug he unit off then on again.
Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle.
Posted on Apr 23, 2011
I need a manual for the cooks essential pressur cooker # 99700
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Microwave Ovens
Fissler Pressure cooker has steam coming out from the Utimax valve, is this normal?
Hi. Some steam is ok. But when it is running it should be sealed up. The little rocker should be doing it's thing too. Good luck.
Jul 25, 2011 | Microwave Ovens
Cook's essential pressure cooker has an E4 error. Tried everything and cannot get the unit to start
Apr 23, 2011 | Microwave Ovens
Cook's Essential pressure cooker missing the pressure relief knob the one that bobs with cooking. How does one ID the manufacture?
Feb 03, 2011 | Microwave Ovens
Where can I get a copy of a Breville Express Cooker (EXC15) manual? I had a cooker given to me but alas no "how to use" instructions.
Hi I have the same model - I absolutely love it. The only problem is that the seal is broken and because Breville no longer supply parts I'm using it more as a slow cooker!
It's pretty simple to use:
The basics:
1. Pull the handles apart (note you must have the 'pressure lock - the only sliding knob on the lid) in the 'unlocked position'.
2. Set the temperature on Max (only until the meat, onions etc are brown, then turn down to 1 or 2- just enough to keep the orange button 'popped' on the top of the machine
3. turn the timer (bottom dial on the front of the cooker) to an hour (you can always turn the dial more if needed, but not reduce time) by the time you've browned meat & chopped veges, etc that will be about 10-15 gone. I've never had it pressure 'cooking for more than an hour for anything'
3. re timing - casserole takes about 40 min from when the orange button on top 'pops' up (ie. steam build up enough pressure to cook quickly)
4. don't over fill - there's a little cast iron bump about an inch from the 'top' inside the cooker - that's about the max.
5. if you're cooking meat dishes have the dial on the top 'pressure release dial' on 3 - lighter dishes (e.g. soups) have on 1 or two.
6. until you get use to it keep an eye on the orange button - you get to know what temp to put it on by how much steam is released - it it's hissing away, turn the temperature down.
7. makes great casseroles, rissotto, soups (even with dried beans, only about 40 min)
if you ever find a supplier for seals, post an answer!
May 19, 2010 | Microwave Ovens
Need a users guide (manual) for a Cook's Essentials Pressure Cooker Model CEPC 800
Jan 22, 2010 | Microwave Ovens
Microwave Ovens Logo
956 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
