Question about Dimplex Heating & Cooling
I need to find an engineer to service my Dimplex oil filled rad. local area 'Uxbrige '
    Brigadier General:
  • 4,736 Answers
Contact Dimplex, UK Customer Support @ 0845 600 5111 and they can provide you with that information.
Posted on Apr 04, 2011
What kind of oil should be used ?
Read the owners manual from the car or call the service department at the local dealer that services the car. Open the hood and find the white label inside the engine bay that tells about the engine displacement, that label might have the type of oil you need. Determining what kind of oil is needed has something to do with your geographic area (how hot or cold it is in your local area) and how much you drive the car....
Mar 22, 2015 | Cars & Trucks
Oil in the radiator
old post
  1. if you do the service on car, then that is bad. (oil in AF)
  2. if done at JIPHPYboobs. it can be just oil put there.
it will get worse if #1
if #2, go to any real auto shop, ASE shop and get a full flush and fill
to get that gunk out of your engine.
or ask them to do the rad leak down test or exhaust fumes in RAD test.
if all tests pass , its a long distance runner... if not , not.
Mar 26, 2014 | Jeep Grand Cherokee Cars & Trucks
How to set timer
Here is a link to an Owner's Manual for a Dimplex Model that is similar to yours. They all function just about the same way.You can downbload & print the manual if you so desire.
http://www.dimplex.co.uk/assets/product_instructions/Dimplex_Oil_filled_Column_Radiators_UK-Issue_0_H27a.pdf
Hope this helps you.
Jun 23, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
I have lost the brochure for my heater, the Dimplex Eco 2.4kW 11 Fin Column Heater.how do you set the timer?
Emily, if you live in the USA, contact Dimplex Technical Service 888-346-7539 for that information, as well has getting a replacement Owners Manual.
Apr 18, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
A leak has developed on my oil filled Dimplex rad is there any way to fix this thanks
Sadly, the short answer is "No, not safely". Because, repairing it won't solve the problem of why it started leaking in the first place.
Sorry, I wish I had better news for you.
Feb 11, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
Oil filled dimplex leaking oil and funny smell
oil smells funny when its hot you heater is porous needs to be replaced
Nov 29, 2010 | Dimplex OFC2000 Oil Filled Radiator Heater
Is ther any thing special I need to know when replacing my rad for my 96 850 Wagon 2.4 liter. I have drained and removed the old rad which had a broken nipple on the intake side. I have drained the...
Only certain engines need to be purged of the air in there, some engines have a plug on the top for it, some have to be filled on a slant or jacked up, some don't need anything. But you do want to use a premix coolant, 50/50 right out of the jug, or if the old coolant is clean, pour it back in. The tranny oil you don't have to worry about. I would fill it up, keep an eye on the temp gauge and check it every day. If it needs filling, top it off with the same, fill the expansion tank too. If it overheats, then I would check on the purge, It will effect the engine. I can look it up for you, but you can use the google thing too. Hope this helps.
Oct 17, 2010 | 1996 Volvo 850
Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
May 27, 2010 | Dimplex Heating & Cooling
I have 04 yfz 450 and its overheating.I start it let it idle for 5mins and its overheating I no the coolant is circulating there is no water in the oil
Headgasket leak?If you have not done so already try filling up the rad(when cold) and run the engine with the rad cap off and look for air bubbles, or you could go to a radiator service centre to check for carbon monoxide in the rad.
Please get back to me if you require further asssistance.
May 26, 2010 | 2004 Yamaha YZ 450 F
Heating & Cooling Logo
87 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
