Question about Mitutoyo 0-18"mitutoyo Electrnc Digi-matic Height Gage
Reading vary cannot be calibrated - Mitutoyo 0-18"mitutoyo Electrnc Digi-matic Height Gage
    Novelist:
  • 157 Answers
Hello. Here is the link to the height gage page(s) at Mitutoyo, Find the unit you have to verify model/serial number and then access their "contact us" option - they will be able to assist you. Hope this helps, if it does please rate it a four-thumbs up. Thank You.
http://www.mitutoyo.com/ProductTypeResultForm.aspx?type=1262#
Posted on Apr 04, 2011
For seca 763 having problem with the display. All led segment was displayed and weight is varying.Kindly help.
Try weighing an inanimate object, is the weight stable? Maybe you're stabalizing yourself by holding on to something? That will throw it off. all weight must be on the base and not moving to get an accurate reading. If it's still unstable it need new weight sensors and calibration. Probably not a DIY.
May 06, 2015 | Seca 763 Electronic Weighing and Measuring...
Tip
How to calibrate the MSA Altair 4
Want to calibrate the MSA Altair 4 Gas Detector or MSA Altair 4X? Here's how:
1. Turn the MSA Altair 4 and MSA Altair 4X on in normal reading mode. Do this by pressing and holding the center button.
2. Once the MSA Altair 4 and MSA Altair 4X is in normal reading mode, you need to send it into calibration mode. Do this by pressing and holding right beeps at you and the screen asks you to zero the monitor (sensor refresh on the MSA Altair 4X).
3. Now that the screen is asking for confirmation, press the center button once to confirm. This will send the monitor into zeroing mode. Now is a good time to set the monitor down, and grab your calibration gas, regulator, and calibration adapter.
4. Open the valve on your regulator. This is a very important step so you do not ruin your calibration gas cylinder. Now screw it in to your calibration gas cylinder. Close the regulator once you hear gas spewing out of it. This is the signal to know your regulator is good to close. Continue screwing in the regulator until it stops. Do not overturn it.
5. Attach the tubing to the hose barb on your regulator. Make sure the tubing is also connected to your calibration adapter.
6. Wait for the screen to come up asking for you to apply calibration gas. Once this screen comes up, press the center button again to confirm. Screw the calibration adapter in to your gas detector. Once it is screwed on, turn on your gas.
7. Make sure your calibration gas values on the screen match what is on your calibration gas cylinder!
8. Once the calibration procedure is completed, turn your gas off and remove the calibration adapter from the MSA Altair 4 or MSA Altair 4X. The screen will go back to normal reading mode within a few seconds.
9. Congratulations! You have officially calibrated your MSA Altair 4 or MSA Altair 4X gas monitor. Make sure to record these readings in your calibration log!
If you come up with an error, the most likely bet is a bad oxygen sensor, but it could be a number of other issues. Feel free to email me.
on Sep 29, 2014 | MSA Altair 4 Multigas Detectors - 10085989
Can I get the best calibration settings for this model?
Hi, The best calibration settings vary TV to TV because it depends on what looks good to the person as well as the type of room you're in. If you can't seem to find settings you're happy with there's many services that can professional calibrate TVs to your liking.
Aug 29, 2011 | Samsung PN51D490 3D Plasma TV
Our Omron BP 755 is reading high. How can we adjust so it reading correctly
My first concern, is how do you know it's reading high? Did you compare the reading(s) with one taken in your doctor's office? If that is the case, it may need to be re-calibrated. In which case, only the manufacturer can do that, as it has to be certified as accurate. Most manufacturers do it at no charge or a small charge, plus shipping. If you are relying on the reading you take at home, then it is well worth it to have it re-calibrated.
Hope this helps you. Please let me know.
May 09, 2011 | Health & Beauty
Varied reading being obtained cannot calibrate is the a recommended repair facitlity in Yorkshire England
Hello. There appears to be a facility in Hampshire, I do not know the limits of the services they offer. But I have attached the appropriate page link for you, click on the "services and support" tab or the "about us and contact" tab - I'm certain they will be able to assist you further. If this helps, please rate it a four-thumbs up. Thank You.
http://www.mitutoyo.co.uk/Mit/mws.jsp?home
Apr 04, 2011 | Mitutoyo 0-18"mitutoyo Electrnc Digi-matic...
I have an Omron Model HEM-711 AC which is about 5 years old. When I use it the reading sometimes it will vary about 10 points if I take my blood pressure several times in the same sitting. Sometimes...
After 5 years, the unit probably needs re-calibrating. In which case, you'll need to have the manufacturer do that. Most off that service free of charge or just a minimal charge. Contact Omron.
Mar 26, 2011 | Health & Beauty
How to check youself / blood pressure for accuracy i get to different reading the first time then upon checking for accuracy the second time the reading is always different
Hello Dear
All Digital equipments vary in its reading. To get the accurate reading take three readings one after the other and then the average of the reading is the accurate one.
Usually the readings varies plus minus 2 or 3 to the accurate reading.
Hope the answer will help, please rate the answer.
Best wishes
Feb 23, 2011 | Lumiscope 1080 Deluxe Auto Blood Pressure...
Compass reading on GPS 60cSx about 30 degrees too high
Calibrate the compass (Main menu --> Setup --> Calibration --> Compass), follow the instructions on the screen.
Also, see page 50 of the manual.
Calibration must be done outside - stay clear of any large metallic object (e.g. car).
Mar 11, 2010 | Garmin GPSMAP 60CSx GPS Receiver
Autohelm st50 how to calibrate??? wind instrument
I had one. Don't think you calibrate it. Reading is relative to it's mounting base. To change the direction reading, you would need to rotate the base.
Jun 10, 2009 | Boating
Mitutoyo 0-18"mitutoyo Electrnc Digi-matic Height Gage Logo
236 people viewed this question
Top Mitutoyo Measuring Tools & Sensors Experts
Doug Adams
Doug Adams
Glenn
Glenn
Are you a Mitutoyo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
