Question about Canon iRC3100 Printer
My ir 3100 shows E045 OHP sensor error - Canon iRC3100 Printer
SOURCE: Canon ir 3100 cn error code e000020-0081
I just had mine serviced for the same code if you take the drum out and wipe the sensor inside the unit that should do it
Posted on Aug 14, 2008
KyoDoc
  • 38 Answers
SOURCE: Canon copier ir 3100 cn error code E000602 - 0202
the hard drive containing the software that drives the machine has an error. Corrective steps would be to contact to a Canon technician, who can first try to re-install the software, and if this doesn't work the hard drive has probably crashed, meaning that the drive will need to be replaced and the software re-installed
Posted on Jan 23, 2009
  • 13 Answers
SOURCE: i have ir 3100 N the error is E 013 please if i
You should empty the waste toner bottle ( open the front door, the bottle is in the middle of the copier, you have to unscrew the small piece of plastic on top of it, remove it, remove the 2 small plastic pieces on each side of the top of the bottle, clean it, empty the bottle, clean it, put the 2 plastic pieces on it, put the bottle back inside the copier, ON / OFF the copier and it ll works :)
Reagrds, Mug71
Posted on Sep 14, 2009
pineworks
  • 4041 Answers
SOURCE: IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Posted on Feb 16, 2010
  • 3 Answers
SOURCE: error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Posted on Jun 04, 2010
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Jun 04, 2016 | Konica Minolta Office Equipment & Supplies
Ohp sensor error in ir2880
OHP Sensor may be out of alignment with the reflector in the Paper Feeder Frame Assembly, there may be a loose connection, or it may be faulty.
Open the Right Door Assembly and the OHP Sensor (with a blue tinted lens) is located on the machine side in the center below the registration roller and the ITB. Ensure that the sensor is correctly seated in the mounting frame and re-seat the harness to the sensor. If code will not clear replace the sensor. (RH7-7129-020)
Jan 22, 2013 | Canon imageRUNNER iR C2880 Color Copier
Error 000045 in ir2880
E045 is the HP sensor error located inside the right door. It maybe dirty or dislodged. Clean or replace. No special reset, just OFF/ON.
Canon ir 3080 error code E0000450000 give me complete answer gust in few minutes
The OHPSensor may be out of alignment with the reflector in the Paper Feeder FrameAssembly, there may be a loose connection, or it may be faulty.
Open the Right Door Assembly and the OHP Sensor (with a blue tintedlens) is located on the machine side in the center below theregistration roller and the ITB. Ensure that the sensor is correctly seated inthe mounting frame and reseat the harness to the sensor. If code will not clearreplace the sensor. (RH7-7129-020).
Jun 09, 2011 | Office Equipment & Supplies
Ir 3100 have erroe 000045-0001
OHP SENSOR ERROR.REPLACE OHP SENSOR
Apr 04, 2011 | Canon Office Equipment & Supplies
My epson c2000 printer have a "service req e033"
Because the Epson AcuLaser Color 2000 was made for Latin America, there's not much information that I can give you concerning your Service Error Condition. All I can tell you is that the Service Request error # E033 is an Engine Related Service Call Error Message for OHP Detection Sensor Malfunction [abnormal condition]. Check to see if the windows on the OHP sensor are dirty and clean OHP sensor window and the OHP sensor reflective window. I'm sorry, but I can't even tell you where the OHP sensor is located, or anything else about it. If you cannot figure it out using your Owners Manual/Users Manual, you can always e-mail Epson Technical Support for possible help or advice, at epson.com
Mar 10, 2011 | Epson AcuLaser C2000 Printer
Error e -070 in canon ir -3100 color copier
Jun 03, 2010 | Canon imageRUNNER C3200 Copier
Hi there
Approved
Symptom
Cause
Action
Feb 16, 2010 | Canon iRC3100 Printer
HP Photosmart C 310series-driver Vindows Vista
Aug 09, 2008 | Canon imageRUNNER C3200 Copier
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Canon iRC3100 Printer Logo
155 people viewed this question
old marine
old marine
