Question about Pentax ME Super 35mm SLR Camera
Sticking shutter/unable to advance film
Hi, My problem with my Pentax ME Super is that when I take a photo, the rear shutter doesnt return fully down. It then is unable to advance film. Once the shutter is fully down it advances the film with no problem. Is this an expensive repair ?
    Scholar:
  • 58 Answers
A used camera will have the same problem unless it is purchased from a specialist as a serviced/reconditioned item.
There are few who do this anymore. (Exept for me that is!)
Alternatively you can remove the parts yourself.
To see how to open the camera up for repair and how to do this properly there is a camera repair site which deal with this and other cameras in detail. alternatively you can contact the author (Me!) who can offer a very competitive camera repair service for these models.
Posted on Jan 21, 2009
  • Gordon Stalker
    Gordon Stalker Jan 23, 2009
    Hi guest we are not tlking about the foam one that sits at the top of the mirror cage. That's a light seal, and is intended to prevent light shining into the viewrfinder getting into the camera space. This can become a problem with small apertures and long exposures requirng a tripod. It matters less if an eyepiece cover is used. It's function as a 'dumper' for the mirror is secondary.
    The ones we mean are three small circular rings of solid rubberlike material. These are mounted on small pegs or shafts fitted on the shutter release side of the mirror cage (See this camera repair website for a better look.) These act as dumpers for the various levert which operate the mirror.
    The worst culprit is the one that sits beneath the mirror relase catch, and on the same shaft. This catch is operated by a lug on the shutter mechanism as the closing shutter lands. Obviously this is quite a light action trigger, and when the ring gets squishy and sticky, it gums the catch, so it does not operate.
    As these dumpers just absorb shocks created as the mirror lifting gear resets, they do not affect camera vibration during picture taking, and so are not critical. I have found after many trials, on dozens of cameras, that they can be ommited completely with no more effect than slightly more noise when the shutter closes.
    However as in the long term this could fatigue the mechansm, replacing them is preferable for long term working. Any durable rubbery material should work fine. I find silcone tubing works as well as neoprene.
    Having said that other models like the MV do not have these rings, and use hard nylon where they are fitted. These do not suffer form this problem, and are not showing fatigue problems as yet!
WITH RESPECT TO THE TWO INTERIOR RUBBER - GOO SEALS I HAVE FOUND FAX PAPER --THE SHINY STUFF, IF CUT TO A VERY THIN STRIP, FITS ON THE TOP OF THE BUMPER COMPENSATES FOR THE SHOCK AND STOPS THE GOOEY BUMPERS FROM CLUTCHING THE MIRROR. THE MORE U. USE IT THE BETTER IT SEATS.
DONT WASTE YOUR TIME CLEANING IT.
Posted on Sep 12, 2008
  • 60 Answers
Probably. That camera has several rubber bumpers and gaskets in the mirror mechanism that have a tendency to turn into sticky gooey sludge causing the levers in the shutter and mirror mechanisms to get sluggish. The only real solution is to completely disassemble the camera to clean out the old goop and replace them with newer neoprene fittings. My suggestion would be to find a replacement body since the repair is probably going to cost between $80 to $90 and you can probebly find a good used body for less than that.
CameraRepairs
Posted on Aug 11, 2008
Rewind button on bottom of camera is stuck in a depressed state and will not release. This causes me to be unable to rewind or load film, shutter button will not cause shutter to click, film advance crank...
Sounds like your camera could use a cleaning and oiling, I'd suggest sending it off to Gus Lazzari for repair. He does good reliable work to film cameras. Hope this helps.
May 10, 2011 | Pentax ME Super 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
Jun 08, 2009 | Pentax ME Super 35mm SLR Camera
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Mar 31, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
May 19, 2008 | Pentax ME Super 35mm SLR Camera
Pentax ME shutter triggered just from advancing film
miraje,
the shutter locking lever is sticking. time for a clean, lube & adjust.
i would take, or send this fine rugged camera to a reputable camera repair shop, have an estimate for a cla.
This model pentax is made with very little plastic and will last a long time with an occasional cla.
Apr 02, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
265 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
