I amtrying to open the filter to clean it but am only able to turn the dial a quarter turn to the left. It is now very slowly dripping water and i cant turn it either way! Is there a special way to turn it or is mine just very stiff?!
    Brigadier General:
  • 6,277 Answers
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour lots of anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
Good luck
John C
Posted on Apr 04, 2011
Bialetti mini espresso coming out very slowly
Hi there... have had this problem. sounds like you have minerals deposit problem. Put vinegar in water tank, then start machine to let all vinegar come out , it should clean it well. then do over again with water so next coffee doesn't taste like vinegar .If by the time the vinegar pasted through and water doesn't come out faster , it must be another problem. Hope this helps.
Mar 10, 2015 | Bialetti Coffee Makers & Espresso Machines
Why does the rinse cold water drip in so slowly?
check filter (screen) in water valve intake and hoses to do so you need to take the water hoses off
Oct 07, 2014 | Whirlpool Washing Machines
How do i fix the Coffee flow from only dripping through?
if it has a filter ,replace. use vinegar through the water resevoir. fill it and turn it on.
May 26, 2014 | Rancilio Silvia Espresso Machine
Bloomfield coffee maker overflows, even with plain filter
The outlet of the cone filter holder is clogged. Normally its just a hole you can clean out but some units have a valve that is pushed up/open by your coffee pot. That valve may be clogged or if you changed the coffee pot it may not be opening due to the different pot. Clean valve or just remove it so the coffee will run into coffee pot.
Nov 13, 2013 | Lands Phones
Machine will not spin dry the clothes and stops mid cycle
Hi ricevans,
Check to make sure that the filter in the pump is not clogged. Open the little door on the bottom and have a towel ready as there will be some water in the pump. Turn the dial slowly and let the water seep out. Pull out the dial and if you see any kind of debris, (lint, coins, etc..) Clean out all of this and put back into place and your machine will work fine. The reason for this is that the pump is designed to pump out all the water in an 8 min cycle if it exceeds the time limit the machine just stops. Hope this helps you out.
Feb 28, 2011 | Whirlpool AWM5104/1 Front Load Washer
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 26, 2011 | GE Refrigerators
Water fliter
For a GE (which you posted under) just turn the filter a quarter turn counter clockwise to remove the old filter. Water will shut off automatically, so you will only loose a few drips. Install new filter by lining up arrow/ cheveron and turning quarter turn clockwise.
Jul 04, 2010 | GE GSS25LGM Side by Side Refrigerator
Leaking pump filter on GE Profile
get new seal for that knob
Mar 03, 2010 | Washing Machines
Water keeps leaking out onto countertop, even when off. Doesn't matter if reservoir is at max or min.
I had the same problem.. I took the clear rubber grommet piece off and added an additonal o ring I had left over from a pur water filter kit and it stops the water from leaking. What does annoy me is that it only pushes water cleanly through for about 30 sec then it drips very slowly for the remaining brew to fill two full shots (I like mine big).
Jan 17, 2010 | Hamilton Beach 40714 Espresso Machine
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
