Question about Garden
Where can I get replacement o-rings for RAC pressure washer HP132? Only place I've seen is Hilka but out of stock for a couple of weeks now. Anywhere else, please???
2 Suggested Answers
  • 30 Answers
SOURCE: Where can i get an
Here:- http://www.hilka.co.uk/product.php?id=1253
Posted on Jun 14, 2011
I am looking for a R.A.C.pressure washer part a water inlet fitting
Fixya does not supply replacement water supply inlets. R.A.C may be the best source.
Jul 27, 2016 | Garden
Need to replace retainer ring on cord for 8 oz kettle on gay nineties popcorn machine model 2131.
That part won't be found online anywhere. Gold Medal is gmpopcorn.com but their parts available online is slim.
The cord for that kettle has 4 different designs possible, only one has a retaining ring.
A small plastic ring on the plug, usually light grey but maybe black. It was only used for a couple of years in the mid-late 80's. Part #47978 coupling ring, small. Pretty rare part actually, I have them in stock. Contact me at kernelpops@yahoo.com.
If you can send a photo of the part you are looking for, (or where it is missing from) it will be easier to get the correct part.
Tim Eischens
Kernel Concession Supply
Mar 25, 2013 | Kitchen Appliances - Others
Can't find the fuel filter to replace it on my toyota tacoma it's a 1997
Its usually behind the engine by the firewall or bolted to the frame under the drivers side a couple feet in front of the fuel tank. Ive never seen one anywhere else on a stock vehicle. Hope that helps.
Sep 11, 2011 | 1997 Toyota Tacoma
I just Replaced the battery on my 2004 harley ultra classic How many cca does a stock battery have?
I've never seen a rating on a stock battery. You may can get in touch with a dealership and they may can give you the rating of a replacement battery. They may have that information but I've never seen a rating in either a parts book or a service manual. Sorry.
Ride Safe
Steve
Jun 23, 2011 | Harley Davidson DNA 50 Motorcycles
My winner 11, has developed a bad leak and has lost pressure, i assume I need a set of O rings, where can i purchase spare parts, i live in Adelaide
If there is no Karcher agent near you, most hardware shops and bearing outlets keep a range of o rings in stock. Take samples ot the part with you to get the correct size and thickness of o ring for your needs. Remember to put a bit of lubricant on the o ring when installing it.
Apr 07, 2011 | Karcher K2.26 Electric Power Washer
I have a Danco 9C-23H/C stem for an American Standard shower stem replacement. I'm trying to identify where the friction ring is supposed to be placed. I've seen it in pictures going on the end where the...
there is never a fiction ring at the washer end, sometimes there is a cup shaped part that holds the washer but nothing else so it must be intended to go around the stem
Jun 27, 2010 | Danco Faucet Stem
Sud and F35
The problem is your analog pressure switch, part number W10156252. If you have the Lowe's warranty like I do, good luck. The repair contractor in the St Louis area is fantastic but the Lowe's parts replacement system is pathetic. The repair part would not be in stock for 5 weeks. The contractor would get the part two weeks later for a total of 7 weeks. I ordered my own from Whirlpool (Lowe's parts source for those products) and found they had 400 in stock. I got the part in 3 days. It's SIMPLE to replace. Remove the top cover (remove three screws in back with allen wrench to remove the top). Standing in the front of the washer, the pressure switch is attached to the right side, at the right rear, near the top. If you reach behind the old switch you can depress the clips so that the switch comes off. Once the old part is free from the attachment point, pull off the rubber tube. Gently unplug the wires (there is a tiny connector keep that you depress to remove the plug). Plug in the wire connector, re-attach the rubber tube and snap the new part in place. IMPORTANT!!!! Do not use any more than ONE TABLESPOON, that's right, ONE tablespoon of "he" detergent from now on. More than likely, the reason the part failed in the first place was from using too much detergent. If you are going to wash ten or twelve oil soaked, grease stained, jeans along with a few muddy towels, use no more than 3 tablespoons. Too much soap is why this part is failing nationwide.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
Garden Logo
398 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
