Hello
If you have ice on bigger copper line and no cooling then the unit is low in freon.
As far as cleaning it,you should clean the outside condenser in the spring.Use some simple green and a hose to clean the coils,this will make it better for the heat to transfer to the outside and cut your costs of running the unit down.
No you can not do freon yourself you need to be cfc certified now,which means you can not buy freon.Best to have a service person come out.
Testimonial: "Direct and to the point. Thank You"
Your indoor unit filter or coil is dirty or your ac low on gas becouse leaking
