Question about Samsung Washing Machines
Do I need 1 or 2 replacement suspension legs for my samsung p1453 washing machine?
    Guru:
  • 500 Answers
You will need to replace both. Replacing one will not help.
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 04, 2011
Testimonial: "thanks, my fault for not realising there were 2!!"
Tub is rubbing door seal. Should it be doing that?
no it shouldent...........more likely the rear bearing is on its way out.......or maybe the suspension legs are shot at.....good luck
Oct 09, 2016 | Samsung WF328AAW Front Load Washer
DOOR IS NOT LOCKED
This video will show you how to open your samsung washing machine P1453 door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2013 | Washing Machines
Samsung WF218ANW drum tilted off track
It may be a suspension spring has come off or leg has broken if it is both drums off track.
If it's just the inner drum then the bearings may have failed or the spider that the shaft is connected to may have broken.
Start with the springs at the top and suspension first.
Dec 29, 2012 | Samsung WF218ANW 4.0 cu. ft. High...
Adora Front Load Washer was stored for 3 years now during the spinning cycle it is uncontrollable and automatically stops the cycle
Your machine has probably got a out of balance sensor fitted to it and when the drum goes out of balance it limits the motor speed to try and balance the load again. If it can't balance the load within so many attempts it will shut the machine off. Either there is to much washing in the machine or when the machine has been moved out of storage some part of the suspension has come off. Check the parts of the suspension on the drum i.e. suspension legs, springs etc. to see if anything has come off.
It may also be possible that some of the suspension may have deteriorated with sitting in storage and may need replacing.
Dec 28, 2012 | Washing Machines
Samsung P1453 about 5 years old, when Spinning is noisy making a banging noise when loaded. If running empty it is OK. When you rotate drum by hand it has one spot that it rubs against. I think there is...
These are on recall. Many are and need to be replaced. Have been known to cause injury. Samsung Top Load Washer Exchange Rebate or they will send a repair free of charge to your home to repair. We replaced our Samsung with LG and are super pleased...same with our son's washer !https://sales.liveperson.net (you will receive an email with your entire chat when you contact Samsung). www.Samsung.com/US/TLW
Sep 23, 2017 | Samsung Washing Machines
Out of balance how do I fix it maytag washing machine model 9457AAE
Only two options are there in it one is upper holding spring & lower suspension problem kindly check whether the suspension two legs will be there both are evenly moving otherwise replace the two legs which is not working fine then go for the upper spring if you found the upper spring problem replace the upper springs
Dec 24, 2009 | Washing Machines
Suspension legs for hotpoint WF740P
change all 3 legs together quote model no.of machine
Jun 30, 2009 | Washing Machines
SAMSUNG P1453 knocking noise at 1200 rpm only
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 29, 2009 | Washing Machines
I have a samsung P1453 washing machine and it refuses to spin, I have checked the obvious like filter and discharge hose,. Is there some sort of sensor to check for load in-balance
hi i also have a samsung p1453 that will not spin when the digital counter gets to 9 mins remaining it jumps back to 10 mins and wont go through the spin cycle the pump is working fine and emptying as it should cann ot see anything blown on the pcb
any advise woulkd be appreciated
May 14, 2008 | Washing Machines
Washing Machines Logo
177 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
