Question about LG W2243T-PF Monitor
LG W2243T Monitor Flickering Problem? - LG W2243T-PF Monitor
How to install driver
The looks of this monitor its just a plug n play but using the Internet to find drivers for it is okay.. Only if you find drivers from LG then you can install them.. But normally if you are connected to the Internet you will be informed that there is a driver for this product in the windows update... but at the moment no drivers so it seems as looked over.
Jan 15, 2013 | LG W2243T-PF Monitor
W2243t need to install driver
This monitor is only plug n play.
My Monitor LG Flatron W2243S keeps flickering and turns off, this started yesterday
Try another good monitor, if it solves the problem replace the monitor if not replace the computer.
Oct 25, 2012 | LG Flatron W2243SPF Widescreen LCD Monitor
I have a LG W2243 monitor and Windows Vista. Every time I change the monitor settings blue screen crash, also can not set the native resolution.
For help on the Blue screen of Death see my tip here: http://www.fixya.com/support/r6836997-blue_screen_death
Judging by the fact that you get the BSoD every time you change monitor settings I suggest that you should update your video drivers.
Jun 08, 2011 | LG W2243T-PF Monitor
How do I adjust image so it fills the screen, side to side and to bottom?
Using the buttons on the screen, bring up the menu.
Then using up/down or left/right buttons navigate to a picture that show a squre that has arrows showing to increase screen size in the approite direction. Select this picture and use the arrows to either increase or decrease size.
Your timeous rating of this solution is much appriciated.
Thanks
Nov 01, 2010 | LG W2243T-PF Monitor
Screen just goes all white then red,green,and blue color flashing
Is it that the screen just went blank or white without any display? need more clarification, but If it is, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
22" FLAT LCD FROM LG
make sure the lcd monitor is connected to a voltage regulator because if your electricity is fluctuating then that might be a cause of the flickering of the monitor. make sure also that the video card of your operating system is configured properly and the drivers are working fine.
Aug 24, 2008 | LG 22" Widescreen Flat Panel LCD Monitor
LG W2243T-PF Monitor Logo
93 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
