Question about Orion HCCA-D2400 Car Audio Amplifier
Why my amplifier was smoking an the music was still playing
  • 4 Answers
Haup ka weak ka nmn
Posted on Apr 05, 2011
Popped lights on no sound
Probably smoked the output IC(it is the chip mounted to the heat sink attached to the fan) which can be purchased from marshall directly or from one of their service centers. Also P-H216 sold at tubesandmore.com should work. No soldering required. Look at that IC(chip) to see if it looks burnt or has a crater on it which would indicate that that is indeed you bad component.
Mar 18, 2014 | Marshall MG100HDFX 100-Watt Amplifier Head
Tip
Connecting your computer to an amplifier to play music
Do you want to connect your computer to a amplifier or surround sound, and play music from your computer through the amplifier? If that is the case, you will need to get yourself a cable from your local sound shop. Ask for a "Stereo to RCA" cable. Plug the stereo jack into the back of your computer (where you would normally plug in your desktop speakers) and plug the RCA cables into one of your open channels on your amp. Select "CD" on your amp if you pluged it into the CD channel, and there you go
on Dec 02, 2009 | Audio Players & Recorders
Amplifer fried???
you can open the case to see if its burnt inside but most likely it is :( sorry. but whatever you do check your main power wire before you put another amp in. I suspect it caused the problem 6_9_2013_5_00_52_pm.jpg
Jun 08, 2013 | Audio Players & Recorders
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
Hi i have a mtx jackhammer JH202 amp and a mtx jackhammer jJH5510D sub and every so often when a song is playing there will be bass and al of a sudden it will shut off and after a few minutes it will come...
The problem was caused by you trying to run a 2OHM load on an amplifier which is designed to run only on 4OHM when it is bridged, the amplifier is most definatley cooked. An authorized MTX technician should take a look at it, to determine just how wide spread the damage is.
dreamsystems.
Feb 11, 2011 | MTX JackHammer JH202 Car Audio Amplifier
The part connected to the fan started smoking
Usually an aluminum heat sink is connected to the fan or near it and an amplifier chip/stick is on that. If that is what smoked, you need to take it in for replacement. Continued powering of this could damage the speaker.
Feb 11, 2011 | Marshall Amplification Marshall MG250DFX...
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
My amp plays but it smokes
Please, Please, stop using it, the fact it plays is a malfunction in itself, so get it fixed or get a new one b4 you light your car on fire...
Oct 07, 2009 | US Acoustics USX-2100 Car Audio Amplifier
Smoke coming from visonik v4218
Generally, smoke means the power supply FETs have failed. There may be other problems that could have caused it to fail. It will need to be repaired.
Let me know if you have any other questions.
Aug 08, 2008 | Visonik V4218 Car Audio Amplifier
Orion HCCA-D2400 Car Audio Amplifier Logo
79 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
