Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune is stuck on connect zune to your pc. re-installed software repeatedly, wiped hard drive, shows on computer as a unknown usb drive. tried downloading firmware and it wouldnt work. Removed battery to reset, that didnt work, i have done everything I have read everywhere. Please help!!!
SOURCE: zune problem
Download and install the latest zune software from microsoft. Run the new zune software, plug your zune into the computer and it should prompt you to install the latest firmware automatically. This is all that is necessary with the majority of firmware problems.
Posted on May 14, 2008
SOURCE: Can't get my Zune software to forget my device
my zune is not turning on please help even when i plug it to the pc it doesnt work.
Posted on Aug 03, 2008
  • 10 Answers
SOURCE: zune reset
Hi I can help you this is how. BUY A 4G ZUNE!!!!! cause your 30g zune is broken or something, or reset everything and instal it again
Posted on Jan 31, 2009
SOURCE: Windows 7 (64 bit) build 7000 and zune problem
i had the same problem at first with my 3rd generation zune. first you have to open up the zune software folder then right click the short cut and click run as administrator then it will detect the device and everything will work. good luck
Posted on Mar 21, 2009
SOURCE: Broken zune
here's a solution! haha
you could sell it to me, i'm looking for a broken zune to swap out parts with my current one.
if you're interested, you can e-mail me at task_master29@hotmail.com
unless you've got it fixed by now, i've heard a ton of people with this problem and really no solution except for send it in to microsoft for repair.
good luck!
Posted on May 10, 2009
My zune is not recognized by my pc
Try rebooting the computer, starting the Zune software and plugging it in again. If this doesn't fix the problem, try uninstalling/reinstalling Zune software, then reboot the computer and plug it in again. If it still doesn't work, then the computer will have to be restored to an earlier date where the pc recognized the zune.
Oct 04, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Nothing wont come up on my computer
Did you download the Zune software?
The Zune website has the Zune software which must be downloaded for your computer to communicate with your Zune.
And when you connect your Zune to your computer it should begin charging (as I'm assuming this is a new device).
If you have already installed the software I would assume the low battery was slowing the communication between your Zune and your computer.
If you Zune is fully charged and the software is fully installed try plugging the USB cable into a different port. Sometimes the Zune and the connector USB isn't automatically sensed on certain ports and certain moments.
Jun 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune won't respond to any key presses.
I would first allow the Zune to completely charge (the battery symbol should be full and green[i believe--it's been a while since I first got mine]).
I would then unplug the device and restart the computer. Once your computer has completely rebooted connect the device to the computer and see if it detects the device. It should work. Also you might try another USB port.
Jun 07, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 4 gb Zune was charging and now it wont come back on!
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software
View products that this article applies to.
SYMPTOMS
When you try to use Zune Software, you experience one or more of the following symptoms:
• The Zune device is not detected by the computer.
• The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message:
No Zune device connected
• If you restored the Zune device software, the following messages are displayed on the Zune device:
Connect Zune to your PC
On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY
To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step.
2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position.
b. Press and hold the Back button as you press the top of the Zune pad.
When the Zune device begins to restart, release the buttons.
3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle.
6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base:
927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device
8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base:
941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista
If you are not using Windows Vista, or if the issue is still not resolved, go to the next step.
9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
b. Click Device Manager. Zune should be listed under Portable Devices.
Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device.
Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties.
2. Click the Driver tab, and then click Update Driver.
3. Click Search automatically for updated driver software.
4. Click Install if you are prompted to do this.
5. After the driver installation is complete, click Close.
If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver.
2. Click Browse my computer for driver software.
3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK.
4. Click Next.
5. Click Install if you are prompted to do this.
6. After the driver installation is complete, click Close, and then click Close again.
10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
c. Expand Universal Serial Bus controllers.
d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base:
310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager
11. Try using a different Zune Sync Cable.
Apr 10, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
How do i install the device to this computer? my mp3 player is Zune its 4gb its comes with everything but not a disc to show me how to work it? im lost with this product? help me asap..
use this link to download Zune software from Microsoft .http://www.zune.net/en-US/software/default.htm turn on the player and connect the player to your computer using the usb cable, once connected windows will recognize the player and install drivers.
double click on my computer on your desktop and you should find the Zune drive.
Feb 21, 2009 | Microsoft Zune JS8-00001 Digital Media...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
I have a brand new Zune 8 GB player, given as a gift. I downloaded the Zune Software, but when I connect the player by the USB cable, the Zune program does not recognize a Zune as being connected. Also,...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps
ALL YOUR BASE BELONG TO US - is a video that must have been loaded on the Zune previously.
if all else fails...
If you connected the ZUNE to your computer before installing the software the computer may have installed it as a different device.
Go to Control Panel - then System - Device Manager. Plug in ZUNE player and see if any new devices show as being connected. BE CAREFUL IN DEVICE MANAGER THOUGH, IF YOU UNINSTALL THE WRONG ITEM, IT COULD MESS YOUR COMPUTER UP.
If this works rate it a FIX-YA!
Dec 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
PC will not detect my zune.
Hey!! I just fixed mine! I had recently installed drivers for a PS3 controller, and for some reason those were conflicting with the Zune.
To fix it, I went to add/remove programs, and then removed the libusb program, that fixed it instantly! Good luck!
Dec 04, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
152 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
