Question about SIB 54M 54mbps WIFI Wireless G LAN Network PCI Adapter Card (885480277414) 802.11g/b
Free Driver for sweex wireless pci card 54mbps LC700050
Download driver
Please open Device Manager, open the properties of the wireless card, and go to the details tab.
In the drop down box, select Hardware IDs
Please post back with the Operating System in use, VEN, DEV, SUBSYS and REV of your card and we can find the exact driver for you.
Mar 16, 2014 | Sabrent 802.11g 2.4GHz Wireless PCI...
After a memory upgrade on PC my wireless PCI card does not know
Hello try renewing the driver from here:
http://downloadcenter.netgear.com/en/product/WG311v1
You maybe have to know the version number to get the right driver.
The number should be printet in on the product.
Good luck
Nov 27, 2012 | NetGear - WG311 - 54Mbps 802.11g/b...
I have a sweex WIRELESSPCCARD11G 54MBPS WIRELESS PC CARD ADAPTER BUT I HAVE FORGOTTEN MY network key
Loginto your router - and you should be able to see it in the wireless section, on some router the password is also printed on a label on the router somewhere - that's they only way to find out the key legally
Apr 12, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Sweex Wireless 54G Card PCI I want to insert this into my Dell Dimension 2400
open the casing of the system. at the lower part, you will see 2 slots. you can insert it in one of them. put on the system and then install the driver for the card. pls rate me. thanks
Jan 22, 2010 | Dell Dimension 2400 PC Desktop
Is there any Windows Vista Driver for the ZIO 802.11g 54Mbps Wireless LAN PCI Card???? I can not find any driver specifically for Vista!
for a good quality solution you might need to ask a premium question its worth it you get answers in seconds and for a bit more you can talk live to the person.
Dec 30, 2008 | Computers & Internet
Wireless network adapter(code 10) and pci modem (code 28)
install proper driver then set ip adress .
enable wireless adapter.
Oct 07, 2008 | Trendware TRENDnet TEW-421PC 54Mbps PCMCIA...
System do not reconize the PCI card
Does it ask for a driver to be installed? Or have you got the wireless version of the mobo that needs an ASUS WiFi-b add-on card with an omni-directional antenna?
Like on the previous version of the mainboard, the PCB contains five PCI slots and an exclusive WiFi slot, in its left part. By the way, when you install the original WLAN card from ASUS into this slot, the last PCI becomes unavailable. Now let’s examine the card, too.
The card supports the wireless networking protocol IEEE 802.11b, describing data-transfer rates up to 11Mb/s. Using the software that accompanies the card, you can use it in the Ad Hoc as well as in the Infrastructure mode, and the card can perform the functions of a programmable access point, providing connections to 31 clients. Thus, the owner of the WiFi-b kit can easily deploy wireless networks and connect to existing ones.
Jul 11, 2008 | ASUS 802.11G WIFI-G 54MBPS WIRELESS LAN...
SIB 54M 54mbps WIFI Wireless G LAN Network PCI Adapter Card (885480277414) 802.11g/b Logo
146 people viewed this question
Top SIB Computers & Internet Experts
Piyal Perera
Piyal Perera
Nathan
Dan Shibata
Dan Shibata
Are you a SIB Computer and Internet Expert? Answer questions, earn points and help others
