Led Stand-by Permanently Ligts - Televison & Video
  • 760 Answers
Please include make and model of your unit. This will help in diagnosing your problem.
Posted on Apr 04, 2011
Jurking in the wheel motor completly shut down and all ligts on dash came on when restarted ligts go out and very hard to steer.
Could be alot of things and sounds very serious and dangerous...Need to have mechanic look at it....I would not fill comfortable giving suggestion as to what it could be....PLEASE have mechanic look at it.....good luck and hope info helps...
Aug 16, 2012 | 1997 Chevrolet Cavalier
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
How to find power shlots & etc for mecury PMNCP73V mother bord
Here is a picture for reference
SYSFAN1 is the case fan power supply ATX1 is the plug in for your power supply in the case PJ1 is another power supply plug SW1 is the assorted jumpers to power on and off computer from the case as well as the LED ligts present
Apr 13, 2011 | Mercury P4VM800M7 Motherboard
Please help me for may led monitor asus vh197d how to remove the base to put in to a wall tns
Mar 30, 2011 | ASUS VH197D LCD TV
The refrigerator side ligts shorted out. The
you need to replace the motherboard located in the lower rear area of the unit,especially if you just lately had a refrigerator light bulb burn out,as this creates a surge and ruins the boards electronic trace,the above symptoms you described point to this it is very common,also if you hear a rapid clicking of a relay and the lights are strobing or dimly flashing this is another sign of the board being defective
Feb 02, 2010 | Whirlpool GS5SHAXN Side by Side...
Can you wire led ligts directly to the 04 harley softail wiring harness for neutral and turn signals
If you are using the full 12+ volts of the bikes electrical system,NO you will destroy the led.
You will need to add a dropping resistor in series with the led so V does not exceed the Vmax of the led.You also don't want to exceed the max current of the led.Most run about 0.020 amps.
You may find leds for sale in the aftermarket auto industry with the resistor preinstalled.
If you don't find these leds let me know what leds you want to use and there specs and I can tell you what resistors you will need to install,led specs can vary from the color ,size and maker.
Thanks,Eric
Sep 23, 2009 | 2003 Harley Davidson FXST Softail Standard
Stuck on standby
Neovia Neo-3775: Standby Led permanently on amber when powered up with no screen or sound. Does not respond to remote or to TV controls.My problem is same as Ed's posted in 2009 - any ideas?
Jun 22, 2009 | Philips TP2785C 27" TV
High beam not working
yes there is have you checkt the high beam ligts. there is one lamp tho the low beam ligts (50w) usaly and there is one lamp tho the high beam ligts usaly (100w)
Jun 08, 2009 | 1999 Daewoo Nubira
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Technics SUV500 problem in stand-by
The problem is not the relay. The unit is trying to start, but detecting a problem and shuting down again. Check the output transistors for a shorted condition.
Dan
Jan 31, 2008 | Technics SUV500 2-Channel Amplifier
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
