Question about LG Televison & Video
When I turn my TV on there is sound, but, the picture vanishes after a couple of seconds. Why?
  • tim lundin
    tim lundin Mar 07, 2016
    hello, i have simailar problem, have you found a way to fix this?
  • LG Master
  • 2,098 Answers
Hi Ken,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This was caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer was faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this was busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 04, 2011
  • 325 Answers
The backlight inverter is what powers the screen to "light up." You will need to check your power supply for the proper voltages going to the backlight inverter. If those all check out ok, then you need to replace your inverter to get your image back. You can find a new inverter by searching "inverter + model number of your tv.
Please rate if this helped :)
Sanyo LCD TV has green light , no picture or sound.
You have the classic symptoms of a power supply failure. Visual inspection of capacitors is not a reliable method of solving the problem
Mar 08, 2013 | Televison & Video
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Wega FD Trinitron dark Picture
probably is only adjustment inside the tv or you may need to replace the flyback
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture fails
hi,
sounds like a high voltage issue, it will have to go in, i dont recommend self servicing that. may sound strange but Ive seen several tvs go by way of spouse having a plant above or near the tv, that person watering it and a few hours later mad spouse sitting in front of a busted tv that sounded just like that. also I had a cat that sprayed one and it did that. just a couple ideas for ya.
J
Jul 12, 2008 | Philips Televison & Video
Picture and sound gone
your fuses may have blown off.
open the back panel and check all the fuses. There are a bunch of fuses in there, my tv has 5 altogether.
I hope this is the problem.
Feb 24, 2008 | Televison & Video
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Picture vanished
The problem might have started because of loose conections in the vertical circuit,if the vertical circuit fails completly the screen blanks out to prevent a line being burnt in the picture tube so that part is normal but the problem is still in the vertical circuit.Maybe the IC just went bad all the way and it might have taken a fusible resistor. If you are familiar with tv service you have a place to check but if you are not too familiar be safe and call for assistance from a servicer,is a straight forward problem and it should not be expensive.Let US know how it goes or if you need more information.
Oct 30, 2006 | Philips TS2754C 27" TV
Televison & Video Logo
239 people viewed this question
