Question about Dishwashers
Hi, I have a Kenwood KDW1274W dishwasher which showing E3. It starts a cycle but does not complete. The dishes are not washed and there is water in the bottom, can you help?
  • 30 Answers
SOURCE: Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Posted on Jan 05, 2007
SOURCE: dishwasher issue
Have had this problem twice on my DWI614. First time engineer came out and I watched what he did and asked questions. He removed panel at bottom of dishwasher (2 screws) after removing facia panel from kitchen as it is a built in dishwasher. To the right is the drain pump. Remove 1 retaining screw and hose retaining clip. Ease out the drain pump and make sure to have some cloth beneath as residual water will flush out. Before I did this the second time I removed as much water from inside with a small cup first. Both times I had blockages in the drain pump. First was a piece of glass and second some food. I also pulled the drain pipe forward and blew through to make sure path to sink was clear. Clear out and reassemble. Start a simple program before putting the front back panel back on and you can touch the drain opump and feel it working as the water drains properly. That was my fix both times, good luck.
Posted on Jun 17, 2008
  • 218 Answers
SOURCE: Bosch dishwasher fills with water after cycle is completed
Sounds like you need a new water inlet valve. It's not shutting off completely, so water slowly enters the machine even while it isn't running.
Posted on Jul 03, 2009
  • 96 Answers
SOURCE: Fault E3 on a kenwood dishwasher...
timer is bad
Posted on Dec 06, 2009
duotom7
  • 6 Answers
SOURCE: dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Posted on Mar 18, 2010
My kenwood kdw1274w is leaking from under it can you help and bit a lot of water
Check your hoses underneath the dish washer. After a while, they sometimes start to leak where they connect to the pump, etc. Also, sometimes they can crack and start leaking. I would replace the hoses, unless they look fine. Then you should just tighten the clamps on the hoses, if you can.
Mar 09, 2011 | Kenwood Dishwashers
My kenwood KDW12SL3A dishwasher dysplays E3 error every time I use it. dishes don't get cleaned properly. Can I fix it myself? if not how much will it cost me to get it fixed by a professional? thank you
Hi
E3 error code neans the water is not being heated to the required temperature in the machine.
This may be either a defective heating element or faulty thermostat.
It is unlikely you can fix this yourself.
Depending on what is wrong it might cost you around $150
Dec 20, 2010 | Kenwood Dishwashers
SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 13, 2010 | Kenwood KDW243A Builtin Dishwasher
Dishwasher leaving a white film on dishes after wash/dry cycle
Mar 18, 2010 | Kenmore 16764 Dishwasher
Kenwood dishwasher flashing E3 towards end of programme and not finishing cycle
As far as I know, E3 on a Kenwood is related to the temperature sensor, when you open it, are the dishes warm?
Dec 03, 2009 | Kenmore Dishwashers
E3 showing on Kenwood model KDW243A
E3 means longer heating time. Usually this indicates the heater element has failed.
Aug 01, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
My Kenwood Dish washer KDW243A has the Code E3 showing, its working but not heating up the water
If you inspect the heating element at the bottom of the dishwasher, you will probably find damage. Replacing the element is the next step.
Good Luck!
Jul 07, 2009 | Dishwashers
Kenwood dishwasher Comes up E3
I do not know the Kenwood dishwasher, hence I do not know what the E3 error is, but many dishwashers require a sustained pressure of at least 30 psi.
Can you please post the model number of your Kenwood dishwasher?
Apr 11, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
