Question about Sharp EL-531VB Calculator
Exponential form how do i use the sharp EL-531 W calculator using the exponents
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
EL-531 W
You need to set it to "SCI" i.e. scientific mode to show the exponents:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 06, 2008
Can my calculator do exponent calculations, "LN" calculations, and has memory capability? If so how do I use them?
Yes, yes, and yes.
You may view/download a copy of the manual at Owners Manual User Guide for Sharp el 531x scientific calculator
You'll find examples of exponential and logarithmic calculations in the second column of the second page and the memory instructions in the fourth column of the first page.
Jan 10, 2015 | Sharp el-531x scientific calculator
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
How do i enter an exponent on the
It depends on the base of the power function.
For exponential function use [SHIFT][LN] (e^x) followed by the exponent value. If exponent is negative use the change sign +/- key before exponent.
For a general power, type in the base (number), then press the [Y^x] key followed by the exponent.
For a power of 10, use the [Exp] key. Careful here. For example to enter 1.6x10^(-19), type in 1.6, press the [Exp] key, then the change sign key +/- and the exponent. Press [=]
1 . 6 [Exp] +/- 19 [=]
Sep 28, 2014 | Sharp EL-531WBBK 12-Digit 272-Functions...
How to plug in exponents on sharpe EL 501X calculator
Type in your base and then press the button that says y with an x as an exponent (last row of the small buttons, second from the left). and then type in your exponent.
Apr 09, 2014 | Sharp Shar El501xbwh El 501X Basic Science...
Is it possible to do exponents other than 10 on a SHARP El-W535X Scientific Calculator?
Use the y^x key (two keys up from the 7 key). For example, to calculate 8^9, press 8 y^x 9 =
Feb 04, 2014 | Sharp Office Equipment & Supplies
Where is the exponent key on the 531x
If you mean the key to raise a number to an exponent, it's the key marked "y^x", two keys above the "7" key. If you mean the key to enter an exponent of ten, it's the key marked "Exp", just above the "7" key.
Feb 18, 2013 | Sharp el-531x scientific calculator
Whats the exponential form of 135
Frankly, I do not understand what you want.
I will try to guess.
Calculate the exponential of 135
Use the [2ndF][LN] key to access the exponential e^x
[2ndF][e^x] 135 [=] result is 4.263389948 x 10^(58)
or 4.263389948E 58
Represent 135 in scientific notation
135 =1.35 x10^2 or 1.35 E2
Represent 135 in Engineering Notation
135=135E0
If none of the above answers your question, maybe you should state clearly what you want, I am no seer.
Hope it helps.
Oct 26, 2009 | Sharp EL-531VB Calculator
How do I get factorial function on a Sharp EL 531 WH
The factorial function is shown on you calculator as n! To calculate factorial 4 you proceed as follows 4[2ndF][n!][=] this gives 24
Hope it helps.
Jun 01, 2009 | Sharp EL-531VB Calculator
Where is shift log feature in sharp EL-531 W calculator
The [2ndF] key allows access to other functions. I do not have the calculator under my nose, but I suspect under the [2ndF][LOG] you access the 10 to the power x function [10^x] or [10 to the x].
Hope it helps.
Apr 08, 2009 | Sharp EL-531VB Calculator
Sharp EL-531VB Calculator Logo
636 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
