Question about Hitachi H45MR 12lb. SDS Max Chipping Hammer
Tengo un demoledor hammer hitachi, pero no se que aceite se usa
3 Suggested Answers
  • 247 Answers
SOURCE: recuadro negro en el centro de la pantalla modelo 55fx20b hitachi
in english please
Posted on Jan 11, 2009
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
Como le echo aseite ala tras moci?n de mi mercury montanier 2006
No estoy seguro como es con el Mercury pero yo tengo un Pontiac Sunfire 2001 y NO SE LE DEBE NI SE PUEDE ECHAR ACEITE DE TRANSMISI?N. En caso de faltar aceite de trnsmisi?n debe hac?rsele matenimiento en un taller especializado ya que debe tratarse de una falla GRAVE
Apr 25, 2015 | Mercury Cars & Trucks
Mi malibu maxx 2004 necesita un cambio de aceite cuando lo compre me dijeron qe el aceite que lleva es color azul pero me dicen que no existe ese color!
hola , tengo un carro malibu 2004 , y creo ke esta kemando aceite , hoy ke trate de prenderlo me encendio la luz del motor , le cheke el aceite y le asia falta , le puse , pero la luz no se le apaga y cuando le aselero tiembla cual podria ser el problema , me podrian guiar por favor
May 29, 2012 | 2004 Chevrolet Malibu Maxx
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Tengo el problema de que el carro ensiende pero despues de unos minutos como que se ahoga y se apaga y ya no quiere arranacar ademas de que no puedo regular la temperatura ventiladores funsionan la tem...
Hola, primero hay que arreglar lo mas urgente que es la temperatura, para esto lo primero basico es cambiar el termostato de temp del agua. Y sabremos si se apaga por lo caliente o porque.
Lo de los cambios tardios no deber de afectar el cambio de aceite asegura se la haya echado aceite de transmission adecuado hay un tipo para cada marca GM (dexron) y Ford TipoF (el Pontiac es GM) y revisa el nivel adecuado encendido el vehiculo y neutral
Dec 20, 2017 | 1999 Pontiac Grand Prix
Tengo un problema con un cadillac deville pasa el aseite al anticonjelante se calienta y pierde mucha fuerza asta no kerer correr mas el mecanico dice poder correjir el problema cambiando los empakes pero...
el problema de aceite mescandose con el anty congelante es por lo regular empaques de cabeza pero en algunos casos puede ser solo empaques de manifool de admission o en terminos usuales diriamos empaques de la arana asegurese que el mecanico le de un precio en caso de que solo sean los empaques de arana por logica seria mucho mas varato que los de cavezas. el caso de la cantada a que se devio le faltava agua? o estava tirando talves bueno a menos que la transmission no trabajava bien antes de la primer calentada estaria en mal estado pero si trabajo bien antes no tendra ningun problema. espero este comentario le ayude para ahorrar algo de dinero y trabajo buena suerte, informeme de lo que acontesca y grasias.
Feb 23, 2011 | 1998 Cadillac Catera
Tengo una montero sport 2003 y tiene un problema que no me pueden diagnosticar, humea con mucho olor de ves en cuando es un humo blanco, pero no lo hace toadas las veces solo en algunas ocaciones nada mas,...
tengo una montero 2003 y se le cambio la banda de distibucion y todo bien, solo que fui a una zona alta que esta de subida y a mitad del camino comenzo hacer lijeros tirones, y ahora en pendiente a baja velocidad lo hace
cosa cuirosa, cuando esta fria no lo hace, pero apenas se calienta lo comienza hacer
Oct 25, 2010 | 2003 Mitsubishi Montero Sport
TENGO UN MITSUBISHI DE 95 , LA TRANSMISION 1.8
quizas necesita revisar sensores de transmision,tambien el nivel de aceite,ya por ultimo quizas sea que ya empezo a resbalarse y va a necesitar una transmision nueva o usada.
Sep 19, 2009 | 1995 Mitsubishi Mirage
MI CADILLAC CATERA 99 PASA ACEITE A EL DEPOSITO DE ANTICONGELANTE
tu problema no eran las cabezas sino un enfriador de aceite que se esncuentra en medio del motor por debajo del multiple de admision lo puedes identificar por las dos lineas gruesas que se le conectan, su funcion es enfriar el aceite del motor pero hay defecto de fabrica y la agencia te repone el motor gratuitamente o puedes comprar la refaccionen la agencia la cual viene perfeccionada por el precio de 350dll
Sep 08, 2009 | 1998 Cadillac Catera
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Velocidad de PROCESADOR PENTIUM III
Si se trata de un portátil es que revela la actual velocidad del procesador cuando se ralentiza. Cuando no usas un pleno potencial transformador la computadora portátil que frena a salvar la vida de la batería.
Jun 22, 2008 | Intel Pentium III, 866MHz Pentium III-M...
Hitachi H45MR 12lb. SDS Max Chipping Hammer Logo
268 people viewed this question
Top Hitachi Hammering Experts
John Trevino
Jim Goldsmith
Jim Goldsmith
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
