Question about Ohaus Triple Beam Balance
I have an Ohaus Triple Beam Balance 700/800 Series that sticks. If you push down or pull up on either end of the balance, the arm doesn't return to the "0" line. It just stays where it is.
What is a balanced force?
Higher end turntables have an adjustment for Balance force. This is the balance of the arm such that the needle is off balance to the point where it pushes down onto the record album. The force with which it pushes down needs to be minimal but it needs to be enough to keep the needle in the grove.
1 to 2 grams is nominal but needles usually have the force setting listed.
More info can be had here: https://kb.wisc.edu/wsum/page.php?id=20270
Jul 13, 2014 | Audio Players & Recorders
Parts of triple beam balance
> Problem with the Web Site
> parts of triple beam balance
Click: http://www.google.ca and enter the text: parts of triple beam balance
and click to do the search. Choose from the results, to read the best answer(s).
Jun 15, 2011 | Computers & Internet
I dropped the box holding my Ohaus ruby series scale and now it only shows E. Is there a reset button or anything I can do to resolve this issue?
Sorry there is no reet button. Make sure the battery contacts are still making good contact. If so try to calibrate the balance. If that does not work the balance should be replaced.
Jan 30, 2011 | JR Ohaus -300 Ruby Jewelry Scale, 300 x...
For the Health-o-meter physician's beam scale, how do you know when it is in balance? What should you do to get it in balance?
For any scale you need to have a known weight to calibrate the scale. Try using something like a 5lb bag of flour or 10lb bag of potatoes.
On the top of the scale set the scale to whatever known weight you have on the platform and see if it agrees, if it is just slightly off, then use the adjustment screw to fine tune the scale, it will be at the end of the left side of the arm.
Dec 27, 2010 | Health-O-Meter Health o meter 402KLWH...
A part is boken inside the measuring cell can I get spares for a AS120 model? for the measuring cell?
Officially at Ohaus the AS120 is no longer supported.
The parts for a PA64 are available. Some of these parts are interchangeble with the older AS120 but I would not recommend an untrained person try to replace them. You can order the parts form Ohaus or any of our dealers. Please remember though all the parts for the AS120 are not available so if something is damaged during the repair it may not be available.
Nov 23, 2010 | Ohaus Analytical Balance Pioneer PA64
What is wrong when the balance reads EEEEHI
It looks like your balance is missing some segments form the digits. It is trying to display 888888 but can nto do it. It needs to be repaired or replaced.
Sep 21, 2010 | Ohaus Compact Scales
Balance is giving me a Err 8.2 message when it is turned on. Unit is an analytical plus model AP250D
The error 8.2 is pretty general. Most likely it is caused by damage to the load cell. There are some things you can try before you decide to get the balance repaired.
1. Turn the balance off and unplug it. Count to 20 and plug it back in anf turn it on.
If that does not work.
2. Put a 100g weight on the platform (the weight does not have to be exact).
3. Plug the balance in and wait for the count down. If the count down starts at 99 you can stop this procedure will not work. If the count down starts at 255 continue.
4.The balance will read error 8.2 again at the end of the count down.
5. Unplug the balance.
6. Remove the weight.
7. Plug the balance in and wait for the count down. The balance should count down and turn off.
8. Turn the balance on and it should work normally.
If this does not work the balance needs to be repaired.
Sep 13, 2010 | Ohaus Measuring Tools & Sensors
Kenmore washer
depends some modles have 2 clips under the front left and right you stick your putty knife in there and pull the console up, also there could be end caps get a screw driver and pop them off then there will be 2 screws remove them. Then some models have 2 screws directly behing the consol remove them pull consol forward and up. Once you have got the consol situated there are 2 copper brakets push down and out with your screw driver this will release the cabinet soyou can replace the lid switch
Dec 26, 2008 | Kenmore 22622 Top Load Washer
Ohaus Triple Beam Balance Logo
Top Ohaus Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Ohaus Measuring Tool and Sensor Expert? Answer questions, earn points and help others
