Question about Zanussi ZKC6020 Electric Kitchen Range
I have a Zanussi ZKC6020 oven, there is a fault on the grill. The top oven heats, but the grill doesn't work. do i need a new grill element? Regards Stuart
3 Suggested Answers
  • 7 Answers
SOURCE: OVEN PROBLEM
have you tested the element with a test meter /
Posted on Jan 07, 2008
SOURCE: Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Posted on Jan 17, 2008
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Fan oven not heating up
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  • If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Apr 24, 2011 | Zanussi ZDQ495 Electric Double Oven
Hi my zbf260w built in fan assisted oven is not getting heat in the oven department.The fan and grill are both fine but not the oven,
If the fan is working o/k, then y ou need to replace the oven element, located at the rear of the oven compartment behind removeable cover.
Sep 26, 2010 | Zanussi Ovens
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Fan in main oven boken
Sounds as if your oven heating element has failed. You need to fit a new one.
Usually you have to get the back off, disconnect the old element, remove the fixxing screws and element, fit new one, reconnect and it should be fixed. Don't forget to switch the power off before starting work.
Dec 31, 2009 | Zanussi Ovens
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Oven not working
Dec 19, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZKC6020 Electric Kitchen Range Logo
65 people viewed this question
Top Zanussi Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Zanussi Kitchen Range Expert? Answer questions, earn points and help others
