Question about Kenmore HE2 Plus Front Load Washer
F21??? intermittantly occuring Unable to unlock
F21??? intermittantly occuring Unable to unlock door after cycle completed.
  • 5,081 Answers
Check this video for the how to resolve the F21 error
Posted on Apr 04, 2011
Does not complete the wash cycles. Has code of F6
The "F06" error code is indicating a Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down. If a failure occurs during high speed spin the door will be unlocked after 3 minutes.
Potential Causes:
Loose wire connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU). Drive Motor MCU Wire harness I recommend calling a service technician to diagnose and repair your washer.
Jul 15, 2011 | Whirlpool Washing Machines
Hi there i have the kenmore elite 45986 my washer is showing f21 i cannot seem to unlock the door i have checked the top drain it looks fine i called to have sears come out to check it out and they want...
Hello, welcome to FixYa.
Based on your post I understand you have a F21 problem with a Kenmore washer, the F21 error means an excessive drain time was detected as you may or may not already know...also the reason the door won't unlock.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time...including unlocking the door. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is)
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for visiting FixYa for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony.
Regards,
Macmarkus :)
May 25, 2011 | Kenmore Elite 45986 Front Load Washer
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
My duet ht front loading whirlpool washer goes through a complete cycle then during the spin and drain ( the last cycle) it displays a f6 notice and will not complete the cycle, you cant get the wet...
Hi
Thanks for using FixYa. Error F06 in your washer indicates that the control is unable to properly detect the motor speed and so the washer shuts down. This usually occurs during high speed spin and the door will be unlocked after 3 minutes. To resolve this issue you’ll have to check the wire harness connections between the Driver motor and the Motor control unit (MCU). If that is fine then check the connection between the MCU & central control unit (CCU), replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 code flashes
Lets see what an F-21 is shall we? F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.3a5b94a.jpgb4a897e.jpg55f108d.jpg
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
May 18, 2010 | Kenmore Elite 45986 Front Load Washer
Door wont open f21 alarm
F21 indicates that the washer is having problems draining. Check the drain hose to see if it is kinked or if there is an obstruction in the hose.
SUD comes on every time excessive suds are detected. Not using the proper detergent will set this off faithfully. The machine will run a cycle to remove the excessive suds before completing the wash cycle.
You need to clean the drain filter by removing the 3 screws in the bottom of the front panel. Then you will see a white twist cap. Remove the filter and clean it out.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
F21 is flashing
This means the water is not draining out like it should. I solved this problem initially on my washer (my drain pipe was clogged), but now (about 4 months later), I have a flashing F21 and 5d, because of a clog some- where. I can drain and rinse (after this cycle, the door will unlock), and the tub spins, but I can't complete a cycle. Lots of debris has come out with rinse water, but I still seem to have a clog somewhere. I can complete a wash load by manually switching the settings.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 error code - will not complete cycle
Check your drain pump. "F21" is a Long Drain error code, which commonly means you have something clogging the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If cleaning the pump does not correct the problem, a new drain pump may be required. If the pump impeller or motor is damaged and the pump does not pump at the proper volume, the error code will still occur. This is because the error is caused if the drain cycle takes longer than 8 minutes. If the pump is not moving the correct volume of water, the error code will still occur.
If a replacement pump is needed you can purchase them at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com or repairclinic.com. All these sites offer great service with competitive pricing. So shop all of them for the best deal. Use your model number (located around the door opening) for your search criteria.
If you have any questions, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 and 5d code
that is because there is a problem with your pump. you need to take the bottom panel off and untwist the pump filter if it has gone further you need to take the 3 screws out of the pump and clean the impeller. try cleaning the pump filter first though and let me know how it goes
Jun 24, 2009 | Kenmore Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
103 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
