I have a 5000btu a/c split unit and I can't get it to take r22 . I can get it up to 30 d F and about 55psi it will freeze up but it will not take freon I cleaned the o tube. do you have any ideas?
  • Patrick Warren
    Patrick Warren Apr 04, 2011
    no expansion vale it has an orifice vale I cleaned it it had a 4 ton outside unit (cond0 and we changed it to a 5 ton the inside unit is a 5 ton (evap)
    Genius:
  • 1,400 Answers
Hello
Is there a low pressure switch,try setting it higher.Next is there an expansion valve?this may be malfunctioning.
Last,stupid question but; does the unit take r22?
Posted on Apr 04, 2011
Testimonial: "thanks good job"
  • 5 more comments
  • Patrick Warren
    no expansion , it has an orifice vale I cleaned it and yes it is R-22 it had a 4 tonout side unit and we change it to a 5ton the in side unit is a 5 ton evap.
  • mpcheesman1
    mpcheesman1 Apr 04, 2011
    You may need to change the size of the o valve,if your going with 4 ton outside and 5 ton inside.
    There is a restriction somwhere,Not allowing full flow of freon back to compressor.
  • Patrick Warren
    they are both inside and outside 5ton it had a 4 ton outside does that mean that the o vale may be a 4 ton and I need to change to a 5 ton o vale
  • mpcheesman1
    5 ton inside,possible you may also need a hard start capcitor kit for the compressor to handle the additional load
  • mpcheesman1
  • Patrick Warren
    Patrick Warren Apr 06, 2011
    why would I need a hard start kit when the evap and the cond are both 5 tons
  • mpcheesman1
    mpcheesman1 Apr 07, 2011
    Sorry didnt read it right 5 ton in and out.No start kit
115LRA how many ton
Your unit is rated at 5000btu which you can covert here:
http://www.rapidtables.com/convert/power/btu-to-ton.htm
Jul 05, 2015 | Heating & Cooling
What is the problem when an air conditioner begins to freeze up?
Freezing up is caused by
•dirty air filter or evaporator coil(indoor coil)
•dirty blower wheel or blower fan blades
•low freon
•weak or slow blower motor
If air filter and indoor coil are clean may be low on freon. Blower wheels seldom get dirty on window units. Pull unit from window and clean both coils with a water hose. Careful not to get any electrical wet. Let dry for a while and reinstall. If it continues to freeze its a freon problem most the time.
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
What is wrong with and Air Conditioner that continues to freeze up?
the ac cant keep up,you need a bigger ac or a smaller room,if the ac needs to keep cooling,it doesnt have a chance to cycle
What the smallest size of ac? 1.5 t
1.5 ton is the smallest in central duct systems, mini split systems 9000btu and window units 5000btu.
May 31, 2014 | Ruud UBHC Air Conditioner
Outside unit freezing
Hi there well it sounds like you got a R22 gas leak thats all
Dec 09, 2013 | Soleus Mini Split Air Conditioner
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
Have 5000BTU Goldstar window unit. Water dripping
the bottom of the case from the outside usually has a "divot" in it below the coil to allow flow from the hose that runs across the bottom of the unit, try pressuring up and "blowing out" any obstruction, if this does not work then you may have to disassemble the unit and verify the drainpan is not cracked below the indoor coil (rare)
Jul 13, 2009 | Goldstar WG5000 Air Conditioner
Split ac not cooling
cak split in door unit 1st watar lavel and in sait watar tra blok paip.
Apr 07, 2009 | LG Heating & Cooling
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
