Question about Tag Heuer Kirium (CL1212.BA0705) Wristwatch
Its brand new,i set the time and date but after a while it starts to slow and gets behind in time.
I just purchased a women's mk 5057 chronograph watch 2 days ago. I believe I set the time properly and according to the manual however it continuously slows down. Each hour it managed to become 7...
Quite possibly but FIXYA has no idea what you might have done . If you bought it thru a local business , go there and have them assist you . even brand new things can fail , possibly the battery has been in it for too long since manufactured .
Sep 15, 2017 | Michael Kors MK5057 Wrist Watch for Men
The day inscription is two days late, monday, watch says saturday
So to change the Day and Date of your Watch, slowly pull the Stem out... (Do note that if you have a Waterproof Watch, you'll need to unscrew the Stem counter-clockwise, which is towards you, until it unlocks, then you can pull the Stem out!) But this is where you need to go slow. If you pull it out slowly you should hear one snap. (It stops on the first notch) If you pull the Stem out all the way, it snaps twice and ends up on the second notch. (See picture below) The second notch, or all the way out, is where the Stem needs to be to set the Time.
day-changed.gif But the first notch, or first snap, is the secret and the key to setting the Day and Date! In the first notch position, you'll see that if you spin the Crown one way, it will change the Day. Spin it in the opposite direction and it changes the Date!
Do keep in mind that you may have to spin the Day and Date a couple rotations because it most likely will alternate between English and Spanish. Just pick the correct Language for you and it's done! When the Day and Date are set, push the Stem in all the way and enjoy your Watch!
If you still have the problem with your Watch changing Dates at Noon instead of Midnight, that just means you're on the wrong 12 hr cycle. (It's set for Twelve at Night instead of Twelve at Noon) All you need to do is pull the Stem all the way out, (second notch) and Spin the Minute and Hour hands ahead 12 hours. If it's Twelve O'Clock, spin it ahead until it's Twelve O'Clock again. Doing that will put the Watch on the correct 12 hour cycle.
Jun 27, 2011 | Watches
How to advance date 4 or 5 days on a Timex T40021
This watch should have a "quick set" date function that lets you advance the dates by turning the setting crown. To get the watch in this mode, pull the set stem out half-way. At that point, turning the setting crown will advance the date on the watch without turning the hands. One some watches, finding the right position for the set stem can be a bit tricky--either it's not out far enough or it's out just a bit too far and the time hands turn. You may have to try pulling the stem in and out a few times to get it just right.
A word of advice: watches are generally designed to advance the date, not to turn it back. It's suggested that if you need turn the date back, you actually advance the date wheel up to 30 days to get to the date you want. Some watches do permit you to turn dates backwards, but I prefer not to risk the chance of hanging up the little springs and mechanism that are designed to advance the date indicator.
One final note: I have serviced several Timex mid-size (ladies or kids size) Expedition watches that lack a quick-set date. Many Timex watches in that size do have a quickset date like I've just described to you, so I have no idea whether these watches happen to have a cheaper movement or if they have some internal damage (it's been the same model each time). At any rate, for those watches, I have had to use the incredibly slow and painful process of advancing the time 24 hours to advance the date. With those watches, if the date is too far advanced by a day or two, it may be easier to stop the watch for 24-48 hours until the date is correct, rather than spend a huge amount of time spinning the crown to advance the time. Hopefully, your watch will have the more sophisticated movement, though.
May 28, 2011 | Timex Expedition® Metal Field 47042...
Bought a new Casio Edifice EF-534D-2AVDF. Unable to pull the crown to set date/time. Can you please guide me how to pull the crown to set date/time
It could be that you need to unscrew it before pulling it out (at feature that is sometimes used to give a better seal).
Turn the crown anticlockwise about 1/4 -1/2 a turn then pull.
Aug 13, 2010 | Watches
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
Nov 12, 2008 | Watches
Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Mar 09, 2008 | Timex Sports Ironman Triathlon 50-Lap...
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
Date setting on Citizen 0510 chronograph
Try this method. Set the date until it reads a couple of days in the past and then set the correct time. Of course do not touch your date or time settings between the hours of 9PM-1AM. Wait until the next day, then move the hour hand forward until you reach the current date with the correct time.
Jan 09, 2008 | Citizen Eco-Drive BL5184-56L Wrist Watch
Tag Heuer Kirium (CL1212.BA0705) Wristwatch Logo
91 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
