Trying to make an IBM 5394 controller work over a v.35 connection using two
cisco routers over Frame Relay.
I have both IDEA Concert 10394-16 (5394 clone) and IBM 5394-01B.
Both work over v.24, and the IDEA works over v.35 (with appropriate cable
changes and AS/400 line description changes). All three scenarios (IDEA
v.24 & v.35 and IBM v.24) work over both modem eliminators and the actual
router/frame setup. The IBM 5394 v.35 does not work either with a modem
eliminator or over the router/frame connection. The IBM 5394 is of "high
serial number" (>55000). It just stays at vary on pending.
Can anyone offer some insight?
Thanks in advance,
Rating: 0%, 0 votes
four twinax devices and the B models up to sixteen.
All of the 5394-01 models support V.24 with the appropriate cable. Those with a serial number above
55000 also support V.35 but they require a special V.35 cable.
The high serial numbers also have a higher internal memory capacity and can support a software PRPQ that
allows them to be configured similar to a 5494. We have several 5394's with this PRPQ attached to WAN
ports of remote routers.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
ways (v.24 & v.35) and the IBM working in v.24, I assume whatever router
software is correctly configured.
Any other ideas?
Rating: 0%, 0 votes
has nothing to do with the router setup !
My mistake - Sorry !
/Peter
Rating: 0%, 0 votes
The 5394-01B support line speed to 19.200bps. but I'm not sure if it's
supports V.35. There are a controller (5394-02B) that support a higher
line speed and can handle V.35.
Best regards
/G??ran Bostr??m
