Question about Panasonic KX-TG3021 2.4 GHz 1-Line Cordless Phone
How do i register my cordless phone Panasonis KX-TG3021CS to my data base.
leroyal
  • 2120 Answers
SOURCE: How to link 3 same model cordless phones to one base
Only if you have 2 phone lines.
Posted on Nov 06, 2008
ryanb006
  • 48 Answers
SOURCE: register hend set to base
Try the procedure on page 62 of the following PDF, and post your results.
http://www.conversationpiece.ie/download/KXTCD505.pdf
Posted on Mar 23, 2009
Schmead10
  • 650 Answers
SOURCE: I cannont register a ATT 2042 cordless phone to
Are you sure it's a 2042...I found 2402 manual http://www.retrevo.com/samples/AT%26T-Telephone-manuals.html
Posted on Apr 14, 2009
ynotphone
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
  • 5339 Answers
SOURCE: I want the user's manual
The handset manual is here: http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/KXTG1100CX-_E (you'll need to rate the product or enter security code to download).
I hope this helps.
Posted on Jul 28, 2010
Testimonial: "It really was useful, as now I can set the settings on my phone and get the ful out of my phone."
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
Mar 24, 2017 | Panasonic KX-TG2356 Cordless Phone
Can I use kx-tga641bx cordless with kx-tg2770bxs base of Panasonic
Yes all cordless phones should be able to be used by the base. If your base and phone is DECT compatible, then you just need to register the handset to the base
Oct 14, 2012 | Panasonic Lands Phones
Register hend set to base
Mar 23, 2009 | Panasonic KX TCD650E Cordless Phone
Kx-tg1100 registration to anoter base
sorry, it seems that they have to come from the same model base. however, the procedure to reset handset numbers for the 1100 may work for you. there is a 15 digit number on the base unit. try to type that into the 1100 and see if that will register the 1100 to your old base.
Dec 12, 2008 | Panasonic KX-TG1100 Cordless Phone
A busy signal
Hi Kevin,
Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
Panasonic KX-TG3021 2.4 GHz 1-Line Cordless Phone Logo
32 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
