Question about Sony Playstation 3 (PS3) Console
PS3 having trouble accessing xmb when turned on.
When I turn on my 80 gig ps3 with firmware 2.42 it makes a crackling noise for the initial turn on music. Then after done displaying Sony Computer entertainment the HDMI access indicator doesn't turn off it just stays solid. Also while it is solid the wavy background is displayed instead of my XMB home page. Once the XMB homepage is displayed it works fine from then on. Problem started with 2.41 and 2.42 did not help. I have restored factory settings. What should I do?
  • 101 Answers
Safe option:
download v2.40 onto memory stick:
http://www.us.playstation.com/ps3/network/updates/pc_update.html#update_PC
install it via update via storage device.
if you can get it back to v2.40, you are lucky, just look at how many people are having problems with there ps3 at the moment on this forum
Posted on Aug 05, 2008
I put the new Mortal Combat game and the Sony PS3 is doing its update, when it gets up to 21% it pops up with error 8002F176, i restart it but still get the same problem. It wont let me leave the download...
Hello.
From the error code you provided, it appears that your update has corrupted during the installation process, most likely due to fragmented data in the update stream. This can happen from time to time, especially when performing an on-line update over a wireless (E.G. Wi-Fi) connection.
If you can get to the XMB, you can try changing your system settings to disable the media server connection and plugging an ethernet cable into the back to update via wired connection. However, if you cannot access the XMB menu at all, and are getting dropped into the update screen automatically, then the above method will do you no good.
Depending on the firmware version on your Playstation 3, you may have access to the recovery menu. To access it, turn off your PS3, and hold the power button until you hear three consecutive beeps, the recovery menu will come up, and you can choose from the available options to attempt to recover your corrupted system.
If the system turns itself off again when holding the power button, your firmware does not support the recovery menu, and you will need to ship your system back to sony to be repaired.
I'm sorry to hear of your misfortune; I myself have a ps3 which is out of commission, and it is indeed a very sad affair.
I hope this helps you in some way.
Sincerely,
Frankie.
May 17, 2011 | Sony Playstation 3 (PS3) Console
Can i myself fix error 80010514 on ps3
Well this is an interesting one; error code 80010514 implies a faulty installation of your firmware.
If you can still access it, try running the System Update (XMB > Settings > System Update).
If the update didn't work, you should backup the data on your PS3 using the Backup Utility (XMB > Settings > System Settings > Backup Utility). What we're going to do to WILL delete the data on your hard drive, so if you don't back it up it'll be gone forever.
Once it's backed up, turn off the console and start it up in
Safe Mode. This link will show you how to access it. Start at option 2 and work your way down through 5. Each option will delete more and more data; option 5 wipes the whole hard drive, thus why we backed up your data.
I'm fairly confident that by using Safe Mode you'll be able to fix your PS3. But if it doesn't work, there's always the option to send your PS3 back to Sony. It'll cost 150$ if you're not under warranty, and you won't see your PS3 for a month or two, but they should be able to fix it. Here's a link to the Service Request page.
Best of luck!
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
My Ps3 makes a loud fan noise after 15-20 minutes
its your backup fan turning on you must not have adequate venitlation take it out of small place and put it near a fan or window
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Search for el dorado
I have the same problem. My PS3 had firmware 2.46 and the Drake's didn't has any problem, never freeze. After I conect my PS3 to intenet (I need update the firmware and download PSN sofware) the troubles begins. Actually I've firmware 3.0, and Uncharted is freezed frequently, then turn off the console, and turn on again, when XMB is ready, go to PSN Home, and back, then go to play to Uncharted, generally unfreeze it.
Sep 02, 2009 | Sony Uncharted: Drake's Fortune
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
My playstation won't turn on!
I know what is the problem the same thing happen to me before you need to open your ps3 and look for a battery that the ps3 have inside. the battery is locate under the motherboard take out and them put it back and this is everything whem you finish try to turn on your ps3.
Feb 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problem
Sounds like you need to update your firmware. The latest is 2.46.
CLICK HERE FOR PSN FIRMWARE UPDATE SITE
copy to a thumb drive, then load to ps3 after wiping the hd clean
You may want to wipe your hd before loading the firmware, it may help your situation.
Sep 06, 2008 | Sony Playstation 3 (PS3) Console
Hd tv but no hdmi plugin,standard red,white yellow plug...when there is a loud noise (explosion,dino roaring etc)I get a loud crackling noise from speakers that actually drowns out the sound fx on a ps3...
Sounds like more of a tv speaker problem then your ps3. You can change the audio settings on the XMB dashboard of your ps3. I think they are default at max.
Mar 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
