Question about Tecnik Washing Machines
URGENT Dear Madam, Sir My washing machines seems to locked somehow, it does make a noise and add and drain water but does not circulate or spin, it makes a noise - the red light for the lock is on but I do not know how to unlock it. The door opens fine. Please can I talk to you urgently? It is a Tennik, TKL 9909 I would be very grateful Eva Nijhof
SOURCE: Duet washer door locked
Pull the front panel off, look for a plastic piece , it has a filter that you need to pull out. turn it to the left pull it out and clean it. This solved the problem for me. had the same issues.
Posted on Apr 18, 2008
  • 4 Answers
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
  • 1294 Answers
SOURCE: door lock on westinghouse mastermind 708 washing machine
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
Posted on Apr 13, 2009
SOURCE: Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
Posted on Jan 18, 2010
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Jul 06, 2013 | Dishwashers
Where can can I pour water for washing cloth?
sir/madam, you cannot
pour water for washing cloththere will be a pipes at backside of the washing machine.one of them is used to expel waste water while other two is used to get water hot water and old water of color red and blue respectively,
Dec 28, 2012 | Washing Machines
Samsung sw68asp manual
Hello & Welcome to FixYa
Please click on this link to download the manual. Please get back if you have any other questions.
Kevin
Nov 24, 2012 | Samsung Washing Machines
WASHING MACHINE WILL NOT DRAIN WATER OUT
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 27, 2011 | Washing Machines
My INDESIT W43T washing machine problem is cannot start,water no come in and i check the door also no lock,i try to another stage,only pump water out system function.another stage no function.what should i...
I have index w43t. it makes some abnormal noise from drain pump and water is not drained. I opened the drain filter and found the noise came from the drain motor. How can i solve this problem?
Aug 02, 2010 | Indesit Washing Machines
Where do I add the washing detergent to?
hi sir/madam, i have attached a video clip showing how to add washing detergent in a washer. i'm sure it would be of great help to you..
http://www.associatedcontent.com/video/18791/how_to_do_laundry_adding_washing_detergent.html
kindly rate me.. thanks for using fixya..
Feb 11, 2010 | Washing Machines
Asko 1475 dishwasher - won't wash. Circulation pump?
Check your drain. It is dual purpose. It not only drains but, it also recirculates the water doring the cycles.
Aug 10, 2009 | Asko Dishwashers
Maytag frontloader washer, seems to wash ok but won't spin water
madam some times the timer of the washer may go wrong and it wont makes the machine to spin so please check it once without loading the machine.
Aug 07, 2009 | Washing Machines
I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Apr 05, 2008 | Washing Machines
Washing machine
most washer weight about 150 to 200 pds.. if you clothes are coming out dry out of the final spin cycle theres nothing wrong...there is always a little water that stays in the washer maybe a gallon or so...
Sep 09, 2007 | Frigidaire FWT647GH
Washing Machines Logo
50 people viewed this question
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
